overall slowness
Hello, I ran every possible Windows 7 DAW tweak before installing PT9. Now there is a very annoying lag between actaully clicking on the mouse, and the line showinging up on the mix window. This also happens when moving a region or anything else. Am I missing something here? It's actaully slower than PT8 on XP (same box, different drive)
I did this to finally access my 8GB and now it's actually slower
2011 MBP / PT 12.7.1 OSX Yosemite 10.10.5 16GB 1333 Mhz DDR3 2.3 Ghz Intel Core i7 Noise Buffet |
Re: overall slowness
Interesting as my rig got much faster going from XP to Win7 64 bit. 2 things to check, if you have open end record allocation(in preferences), change it to 15 minutes(or more if the project requires it). The other is to check your RAM timings in BIOS. With my rig, the AUTO setting netted awful performance. Setting RAM timings manually made a huge improvement. If none of this helps, try posting a Sandra report as it might help you get better advice
Every mouse click has a lag before showing the cursor. How might one check RAM timing info, etc? Here's the report:
SiSoftware Sandra Computer Model : System manufacturer P5QL PRO Workgroup : WORKGROUP Host Name : 7-PC User : 7 Processor Model : Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz Speed : 2.66GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5QL PRO BIOS : AMI 1001 03/12/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR2 Chipset Model : ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 8GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Crucial RM25664AA80016FH 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-23-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Crucial RM25664AA80016FH 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-23-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce 8400 GS (Microsoft Corporation - WDDM v1.1) (8 SM4.0 1.4GHz, 512MB DDR2 2x400MHz, PCIe 2.00 x16) Graphics Processor Storage Devices Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) (F:) Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (C:) Generic USB SD Reader (USB) : N/A (I:) Generic USB CF Reader (USB) : N/A (J:) Generic USB xD/SM Reader (USB) : N/A (K:) Generic USB MS Reader (USB) : N/A (L:) Ut165 USB2FlashStorage 1GB (USB) : 964MB (H:) ATAPI iHAS224 Y (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices Hard Disk (E:) : 128GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) PRO TOOLS (D:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (C:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) Removable Drive (H:) : 964MB (FAT) @ Ut165 USB2FlashStorage 1GB (USB) Hard Disk (F:) : 338GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Removable Drive (I:) : N/A @ Generic USB SD Reader (USB) Removable Drive (J:) : N/A @ Generic USB CF Reader (USB) Removable Drive (K:) : N/A @ Generic USB xD/SM Reader (USB) Removable Drive (L:) : N/A @ Generic USB MS Reader (USB) Optical Drive (G:) : N/A @ ATAPI iHAS224 Y (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller(NDIS6.20) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.4
I meant Windows accessing the 8GB, but dot not know about the PT9 limitation. How can I set the RAM timing to 5-5-5-15 ???
Manually setting the RAM timings will be done in the BIOS of your system. Youtube should be able to help you out with specifics. But is shouldn't be that hard. I have a ASUS board and it was pretty easy.
Like YYR123 said, it's done in the BIOS under Memory Settings. I don't use ASUS so yeah, maybe YouTube can help you out on how to get there. Or, try the manual.
It turns out I had the new install of PT9 on Windows 7 storing projects on the same drive...This was the problem, not the memory settings, which by the way have zero documentation in the manual. That's right, not a shred of info about the massive amount of settings in the BIOS. nothing ...at all, anywhere - youtube yeilded maybe 2 videos of people unboxing the motherboard
CL 5 tRCD 5 tRD 5 tRAS 15 RAM timings is the culprit in many cases but, if all is now working well and stable then I wouldn't worry about it. |
PT 805. / 003r Amd phenom x4 @ 3.2ghz ASUS M4A79T - WIN7 x64
what's causing this system slowness? | viaspiaggia | Post - Surround - Video | 10 | 09-16-2013 10:11 AM |
+4000 IRs & TL Space Slowness | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 07-15-2009 06:36 AM |
Workspace Slowness!!! | M2E | Pro Tools TDM Systems (Mac) | 10 | 09-23-2008 04:43 PM |
6.1 Graphic Slowness | Siegfried Meier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-12-2003 08:34 AM |
general slowness | AdamFrick | Pro Tools TDM Systems (Mac) | 12 | 11-23-1999 09:36 AM |
