Old 04-12-2021, 06:23 PM
1Monty_D3 1Monty_D3 is offline
Default Help! I shrunk Pro Tools!
Help! I don't know what I did, but I made everything tiny! Everything! Somehow I made the whole Pro Tools app, edit window and everything so tiny I can't hardly see it! I can maximize like you can with any window, but everything in it is still teency tiny. Shutting down doesn't help because it opens up the way it was when it's closed.
Dell XPS 15
Windows 10
Pro Tools 2020.11.0
Focusrite 2i2 interface
Old 04-13-2021, 09:12 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Help! I shrunk Pro Tools!
I am a Mac guy BUT ::
If your sure it is something in PT (and not some view option key stroke in Windows)
Try Trashing Pro Tools Preferences ..................
Before trashing Pro Tools preferences, follow these steps to show hidden folders:
Windows 8 & 10
First before trashing PT preferences.... Click ‘View’ in your File Explorer window, then check Hidden items above Show/hide.
Then ::
Trashing Pro Tools Preferences in Windows
Pro Tools 11, 12, and 2018 (I am assuming 2020 .11)
Close Pro Tools.
Hold the Windows key on your keyboard and press R.
When the Run window appears, type %appdata% and press OK.
Open the Avid folder, and delete the Pro Tools folder.
Restart your computer and launch Pro Tools.
System :
Enjoy the Journey
.... Kev...
Old 04-13-2021, 10:36 AM
Top Jimmy's Avatar
Windows has a display setting that essentially magnifies the things open on the screen so that they’ll be bigger when opened on a small screen. I forget the name of the setting but it typically defaults to 125% or more on laptops. Look in your display settings for one that increases the size of windows and apps.
James Cadwallader
Old 04-13-2021, 10:38 AM
Thanks for the help. It was an emergency situation, so I uninstalled Pro Tools & then re-installed it. The most difficult thing for me to learn was that I had to install the same version of PT.
Back to normal now. Maybe your fix would have been better & saved me time.
I could tell it wasn't a Windows problem because no other windows were affected.
Dell XPS 15
Windows 10
Pro Tools 2020.11.0
Old 04-13-2021, 10:40 AM
That's what I thought too. But I couldn't find it. So I ended up uninstalling PT and then re-installing it.
Thanks for your reply & your tip. I'll bet you were right.
Dell XPS 15
Windows 10
Pro Tools 2020.11.0
Old 04-13-2021, 10:42 AM
Back to normal now.
Thanks to everyone for your help & tips.
Dell XPS 15
Windows 10
Pro Tools 2020.11.0
Old 04-14-2021, 05:56 AM
K Roche's Avatar
Back to normal now.
Just know for future reference that Trashing PT Preferences is often a cure for many problems and is a recommended first step to reinstalling, being much quicker. Because you can trash the folder and simply relaunch.
System :
Enjoy the Journey
.... Kev...
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
