Old 11-23-2018, 12:13 AM
Stephen Webster Stephen Webster is offline
Default RX580 + HDX on a Cheesgrater Macpro5.1
Anyone running a RX580 8GB in combination with and HDX card?
I have been through several threads regarding upgrading the GPU's in the cheesegrater Mac Pro's, but cant seem to find a solid answer...
I would like to install a RX580 that needs additional power from the board, which the HDX card is using. It seems though that the HDX card could take power from the unused SATA port with an adapter cable (attached). But i'm interested to know if the power supply will handle this?
Macpro 5.1 Mid 2010, 12 Core, 2.93Ghz
Old 11-23-2018, 10:06 AM
BScout BScout is offline
Default Re: RX580 + HDX on a Cheesgrater Macpro5.1
I do it for my Graphics and the power supply is fine. However, I have the HDX cards wired to the standard power leads and the Graphics wired to the SATA power.
Old 11-23-2018, 02:51 PM
arche3's Avatar
arche3 arche3 is offline
I did a bunch of research. The 580 draws a lot of power. The safest way is an extra external power supply. The SATA power tap can be used but depends on what other devices you are using. Even so. From the mac mods forums they recommend an extra power supply. Which is what I did. You run the lead in from an empty pcie slot back panel opening or remove a optical and put power lead in from front Cdr slot.
Old 11-25-2018, 03:15 AM
Thanks Guys!
Old 03-08-2020, 03:55 PM
innesireinar innesireinar is offline
The 2020.xxx could be mojave and above. Given that now I can't afford a 7.1 I probabily need to upgrade the video card on my old 5.1. The last post of this topic is almost two years old and I wonder what is the best way to go today. I have the hdx. Anyone?
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 03-26-2020, 10:23 AM
iljunegate iljunegate is offline
I'm buying the msi 560. seems it don't need the extra power cable and support metal and mojave
Mac Studio M2 Max 64gb ram 2tb
Monterey (last version)
Pro tools Ultimate 2023.12.1
Avid HDX card | 2x Avid HD I/O 16i/o | Avid MTRX studio
Api 1608 | Avid S1
Dolby Atmos certified 7.1.4 with Amphion Speakers
Old 03-28-2020, 04:42 PM
DetroitT's Avatar
DetroitT DetroitT is offline
2 Mac Pro mini 6 pin pciepower to 8 pin on MVC 580 card (Supplied cables)-((Spliced in for 1-HDX micro 4))
Alt: 1 mini 6 Pin to 8 pin cable for vid plus 1 mini 6 pin to HDX cards (Supplied with Cards)
HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD? alonper Pro Tools HDX & HD Native Systems (Mac) 16 06-26-2018 04:47 PM
Mid 2012 MacPro5.1 6core 3.33 for PT12 ? SD70 Pro Tools 12 2 05-21-2018 04:04 AM
