Old 09-28-2022, 02:38 PM
anearforgear anearforgear is offline
Default AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9
Title says it all. I discovered this when opening a session with AutoTune activated on a track and also opened via AudioSuite. The session crashed and Pro Tools crashed/quit.
When I tried to install a previous version of AT (8.0.4) the same thing happens.
I've tried creating a brand new session with only one track and one plugin, same crash/quit.
Can anyone else confirm?
Mac Mini 2018 / Big Sur 11.7 / Pro Tools Studio 2022.9
Old 09-28-2022, 04:46 PM
Dizzi45Z Dizzi45Z is offline
Default Re: AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9
I don't have AutoTune 8, but I have AutoTune 9 (Pro) and I am not seeing issues.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 09-29-2022, 07:06 AM
mykla mykla is offline
Yes, launching AT 8.1.8 immediately crashes PT 2022.9 both in aax and audiosuite modes! This is bad news, because the subsequent AT releases have a very different user interface that I found very difficult to work with. AVID wizards please fix this if you can!
Old 09-29-2022, 08:19 AM
JFreak's Avatar
JFreak JFreak is online now
Hi, welcome to the community.
Unfortunately it is up to 3rd party plugin vendor to fix their plugin, and I am 99.99999% certain AT8 is not going to get bugfix releases anymore.
Janne
Old 09-29-2022, 11:19 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi !
Antares has been very poor over the last few months or maybe years. After struggling a lot with it too, I ended up buying the UAD Autotune version and it runs amazing. I think the problem is the AAX version. You can try wrapping the VST version too if you don't want or can't buy the UAD one.
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 09-29-2022, 11:24 AM
The Weed's Avatar
The Weed The Weed is offline
Originally Posted by jeam25 View Post
Hi !
If you have the VST3 64 version, get Waves free StudioRack to host it.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-29-2022, 12:05 PM
itsjustmeee123 itsjustmeee123 is offline
I'm curious, what version of os are you running? I have Big Sur 11.2.3 and AutoTune Pro 9.1.1(which I believe is the latest) won't install for me.
Old 09-29-2022, 05:25 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Or use Blue Cat Patchwork.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 09-30-2022, 02:37 AM
Thanks guys. I tried it and AT 8.1.8 works great in Waves StudioRack and not so great in PatchWork (not resizable, defaults to tiny screen).
Old 09-30-2022, 03:53 AM
It's good to see there are some workarounds available, and it sounds like the latest version (AutoTune Pro) is not affected.
However, because MANY of us rely on AT8 today, have to access sessions that used AT8 and/or need backward compatibility for any reason--we need to see an update from Antares and/or Avid on this.
Future use of AT8 via workarounds is not a full solution, particularly because there is no way to even open sessions with the plugin active under 2022.9.
Custom Shuttle Lock Speed broken in 2022.5 [PT-290238] ArchStanton Pro Tools 31 10-26-2022 10:38 AM
Looping regions (Audio and MIDI) broken in 2022.6? XJENSEN Pro Tools 3 07-12-2022 10:26 AM
Is the MIDI zoom on the edit window broken in 2022.05 Windows? snowplaysmusic Pro Tools 1 06-17-2022 06:44 PM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
autotune update to 7.7.4 still broken!! Gems Records Pro Tools 11 2 04-16-2014 07:50 PM
