Old 04-28-2022, 05:35 AM
stargazer stargazer is offline
Default Workspace - monitor through plugins
Is there a way in PT Workspace to monitor through plugins. (e.g. Sonarworks SoundID)
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 05-08-2022, 05:45 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Workspace - monitor through plugins
No, not that I'm aware of.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-08-2022, 07:44 PM
its2loud its2loud is offline
You can, it’s just not a direct path.
Set your audition path in pro tools to something other than your monitor outputs. Say outputs 7&8 if you’re not using them.
Physical patch those outputs back into two available inputs and route those inputs to an Aux Track in your session and route that Aux Track’s output to your monitor path.
Assuming that your monitor path has the Sonarworks plug-in on it in your session.
Old 05-09-2022, 01:44 AM
thin ice thin ice is offline
Can't you use the Sonarworks system wide software? Anything on the computer should play through the attenuated eq.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 05-09-2022, 02:14 AM
BScout BScout is offline
OP is using Ultimate with an Avid Omni which means digilink is the connection. That does not go through Core Audio (so not to System Wide output)
Old 05-10-2022, 05:00 PM
cwsand's Avatar
Yeah there's that. I just assumed the OP meant in Pro Tools internally.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 05-10-2022, 09:41 PM
massivekerry's Avatar
massivekerry massivekerry is online now
I do this. I have Output 1&2 “clean” for bounces, and I monitor everything out of Outputs 3&4, which has the SoundID plugin on it. (I route everything to an Aux that I use as my “actual” Master Fader, which is routed to Outs 1/2 and 3/4). Then I have my Monitor/Preview Output in Hardware Settings set to Output 3/4, so anytime I’m listening to something in the Workspace or an Audiosuite Preview, it plays through the SoundID-enabled Output.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
who uses picture monitor for plugins etc? The Cargo Cult Post - Surround - Video 17 05-09-2013 04:36 PM
Anyway to Drag directly from Workspace to Finder or Plugins? Imbie Pro Tools 10 0 04-20-2013 01:07 PM
Routing Monitor Stereo through Plugins ... Brad Harris VENUE Live Sound Systems 1 04-27-2010 12:56 PM
Is there a way to monitor thru plugins on LE? digidesigner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2010 12:05 PM
Audiosuite plugins don't show on second monitor Wayne B Pro Tools TDM Systems (Mac) 2 09-06-2003 05:55 AM
