Old 04-28-2022, 01:31 AM
stargazer stargazer is offline
Default MacPro7,1 USB-C to optical solution
Coming from a 5,1 I miss the digital output.
What’s the alternatives today for getting a macOS system digital audio output on a MP7,1?
Simple, cheap, USB-C/TB...?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 04-28-2022, 02:07 AM
dominicperry dominicperry is offline
Default Re: MacPro7,1 USB-C to optical solution
Topping D10S if you want nice.
Behringer UCA202 / 222 if you want cheap. Limited to 48KHz, I think.
Or any RME interface if you want excellent drivers.
Old 04-28-2022, 02:31 AM
Thanks dominicperry,
I just need a simple converter to connect to my HD Omni to be able to listen to Spotify, YouTube etc. Nothing critical, was hoping for a TB/USB-C-to-optical/spdif cable.
Old 04-29-2022, 12:31 AM
Thanks again,
Ordered a Behringer UCA222, so I can run core audio in tandem with HDX and monitor through my Omni.
HDX3 on MacPro7,1 power connection Pythagor Pro Tools HDX & HD Native Systems (Mac) 3 07-06-2021 08:12 AM
Hardware/sample rate errors on MacPro7,1 LukeHoward Pro Tools HDX & HD Native Systems (Mac) 4 05-09-2020 05:46 PM
G5 Digital optical out into PT @ 96k solution? crizdee Pro Tools TDM Systems (Mac) 8 06-22-2007 11:18 AM
an economic solution 8 more ins optical ADA 8000 flautista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 06-02-2004 11:46 AM
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? el biciclista Pro Tools TDM Systems (Mac) 2 07-09-2002 10:32 AM
