  #101
Old 01-22-2015, 06:13 AM
Skwaidu Skwaidu is offline
Default Re: Need a new quieter fan to HD IO..
Fixed my HD IO with the silenx fan http://www.silenx.com/quiet.fans.asp?sku=efx-08-15
Most time went into replacing the connector but it was doable, I ordered some spare 4-pin extension cables so I have the original fan intact if I need to reinstall it.
The end result is stunning. Nearly dead silent from somewhat annoyingly loud, my quite quit AC now overpowers the tiny fan noise left. Shame on Avid for leaving such a design flaw into their premium product.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #102
Old 01-22-2015, 02:09 PM
ArKay99 ArKay99 is offline
If using the Silenex fan, no need to cut and solder. Just use an X Acto blade or equivalent and push the tabs holding the pins in down and the wire comes right out. Do it on both connectors, then just make sure the tabs are bent up slightly so they grab when reinserted, and reinsert. As per Meads.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
  #103
Old 01-23-2015, 05:42 AM
Be careful when bending these tabs as they are very fragile; I've broken a few in other instances and when that happens the pins don't stay in the connector housing and have no support. It doesn't mean you can't use it; you just have to push the pin onto the connection on the board and it should stay there. All the plastic housing does is provide support for the connections.
Jack
QAPLA!
  #104
Old 03-08-2015, 12:57 PM
treason treason is offline
I also recently completed this on 3 HD IOs. Amazing the difference , as already noted!
Couple things which I would emphasize after having completed this:
  1. Note that the fan must push air OUT of the HD IO.
  2. a 9V battery can be used on the Silenx fan to determine polarity of the pins (hint - middle lead is +ve)
  3. The delicate nature of the pins as outlined above by musicman691 is critical. These determine the connector's ability to maintain contact. Without enough tension, the connector will fall off, and the fan stop working. Be cautious.
It's a very worthwhile upgrade!
T-
Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
  #105
Old 03-11-2015, 09:04 PM
Fidelis Fidelis is offline
Default Need a new quieter fan to HD IO..
Did two HD IOs here and the results are incredible. Don't here then anymore.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
  #106
Old 03-11-2015, 09:56 PM
cananball cananball is offline
Am I the only one that isnt concerned about the fan? Latest firmware, super quiet. My Mac Pro is louder than my Omni by a lot
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
  #107
Old 03-14-2015, 07:17 AM
Pretty sure this is aimed at HD owner's, although a few posts up front were regarding Omni's. Omni is different in that it uses a 40mm fan IIRC and the HD's use an 80mm.
Also, IIRC the Omni has firmware control of the fan whereas the HD doesn't.
BTW, since I did the change on my HD it's also quieter than my cheese grater, which is pretty quiet, until the angry bee in the HDX card gets hot and starts fanning it's wings...
  #108
Old 03-14-2015, 07:27 AM
Meads Meads is offline
Avid seem to have changed the fans of the Omni in the newer revisions. I had one from 2010 which had a horribly loud fan. Had the unit replaced recently due to a hardware fault, and got a new model. The fan in that one is WAY more quiet. So very quiet, that I didn't neet to bother giving it a fan-replacement.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
  #109
Old 03-14-2015, 09:57 AM
JFreak's Avatar
JFreak JFreak is online now
Do the two boxes have the same firmware or just different fans?
I myself still think that less noise is less noise and the experience I had by swapping an old 192 fan to a silent one is just astonishing. I might just do the same hack for all interfaces when I have some time for it. Just to be sure.
Janne
  #110
Old 03-14-2015, 10:14 AM
They are running the same firmware, and I didn't open up the new unit to check on the fan. But it has to be a different one.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Is the Avid IO fan quieter than the 192 fan? Eric Lambert Pro Tools HDX & HD Native Systems (Mac) 84 02-22-2024 03:56 AM
Are the new HD 8x8 i/o's quieter than the last gen? guitarzzan Pro Tools 9 2 06-16-2011 10:52 PM
Quieter internal drive for new mac pro? bsmith23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-26-2009 04:48 AM
G4 quieter fan exchange Seller Pro Tools TDM Systems (Mac) 0 02-21-2003 08:53 PM
Which PC's are quieter? MGruschow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-03-2000 11:25 PM
