Old 03-19-2006, 09:17 AM
DBro DBro is offline
Default Digital Distortion in Left Channel output of 002
G5 Dual Core 2 MHz
System and Recording Drives
1 GB Ram
Fresh install
10.4.2 and PT7.0
I am getting some High Frequency distortion in my left speaker channel. I thought that I blew a tweeter, I changed speakers and the problem continued. The distortion is happening in the headphone out on the digi 002 also. I just reinstalled all software the the problem is still happening. What in the world could this be?
Thanks for your help
DBro
Old 03-19-2006, 03:15 PM
Default Re: Digital Distortion in Left Channel output of 002
I wanted to add that I just upgraded to PT 7.1 and OS 10.4.5. It is not the speakers as I have swapped them out in every combination. I have re-initialized my system drive and re-installed PT. It is coming out distorted in the left channel of both the headphone out of the 002 and the monitor out. I have tried different sessions and used good tracks with no plugins. When the track is panned right it sounds fine, but from the left there is a High Frequency distortion or clipping. Maybe something is wrong with the 002 unit?
Any help will be appreciated.
DBro
Old 03-19-2006, 10:55 PM
Do you think resetting the G5 with the PMU button is a good idea? I have tried just about everything else.
Thanks
Old 03-19-2006, 11:16 PM
kurt's Avatar
kurt kurt is offline
Was the system ok with previous version of PT?
If so, try to trash ALL digi preferences & repair permissions.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 03-20-2006, 09:49 AM
It started doing it with 7.0cs5. I reinstalled 7.0 and it still did it, the upgrade to 7.1 didn't help. I will try to trash everything again, but when I reinstalled 7.0 I did that.
Thanks for your help.
Old 03-20-2006, 11:11 AM
I called digi today and they said it sounded like a hardware problem. I am replacing the 002 with a refurb unit. Thanks for the help.
Digi 96 i/0 with digital distortion on 1 channel T_S_Harris Pro Tools TDM Systems (Mac) 0 03-31-2011 03:50 PM
002R main left output distortion lazymits 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-13-2008 02:10 PM
Left channel output louder in Mbox 1, please help. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-14-2008 09:40 AM
Distortion from 002R Left Monitor Output thestryder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-14-2008 02:24 PM
Audiomedia III digital noise on left channel GandaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-02-2001 10:28 PM
