Old 10-12-2009, 10:11 AM
Breakdown Breakdown is offline
Default Lost wav. files
Sorry, I posted initially on the wrong forum.
Simply I have upgraded my PC, now with Windows Vista, and added a Fire Wire Hard Drive. Previously I had used an XP based system and a USB driven external hard drive, anticipating problems until I upgraded.
My issue is that the sessions I have saved on the USB drive will not open properly on the new system. All the tracks are there, but no wav. data visible or audible.
What dumb thing am I missing, apart from the data that is......
I have simply dragged the session files from the old to the new.
Old 10-12-2009, 10:27 AM
spkguitar's Avatar
Default Re: Lost wav. files
Answering from your other post:
Originally Posted by Breakdown View Post
Disc Allocation confirm files are not in the right place..And then what...
If disk allocation is showing the wrong location for the files... Change the location.
You would probably be better off doing this:
  • Open the session in Pro Tools from the original USB location.
  • Ensure that everything is there and that the session works as expected.
  • From the Pro Tools menu, select File->Save Copy In...
  • Ensure that the Session Parameters are the same
  • In the "Items to Copy" section of the Save Session Copy dialog, select "All Audio Files" (and anything else that is relevant to the session)
  • click OK
  • Select your new firewire drive as the destination, check/correct the file name as you desire, and click "Save".
Old 10-12-2009, 11:21 AM
Thanks for that. Unfortunately it starts when I try to open th files from the USB hard drive. That is when they are missing. The same files open perfectly, and still do, on my XP set up.
Can't do anything now until Wednesday as I have to go away from home until then.
Again, thanks for your time.
Old 10-12-2009, 11:30 AM
spkguitar's Avatar
OK, that leads me to beleive there is an allocation problem on the original system then. While the session is open on the XP system, check the allocation and make sure the files are on the USB drive.
Which just enhances that theory.
If you can, open the files on the original system, do the "Save Copy In..." process on the original system to the USB drive from the original system first.
This might also have something to do with permissions under Vista. Are you running Pro Tools as Administrator?
Old 10-12-2009, 12:01 PM
TOM@METRO's Avatar
I agree, it sounds like you have audio files in mystery places on the original session. Follow the advice given and you should see them all come together in one place.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-12-2009, 08:27 PM
rqstudio rqstudio is offline
This is truly one of my biggest gripes about PT. (I have 3) If you check in your disk allocation window the system drive should be set to playback only. and the box with 'record using round robbin' should not be checked. I don't know anyone who uses this feature, and if you should not ever record to your system drive, WHY IS THE OPTION EVEN THERE? If someone can explain to me why anyone would want to keep the audio files in a different location from the session, I'd like to hear it.
Make sure your setup is exactly as it was when you recorded your session. Go to the file dropdown and select 'record in' select a drive, and check the box, 'with audio files' just as spkguit suggested. If you haven't performed a defrag or move the files they should be located and moved with the others to it's new destination.
Good luck...
Old 10-14-2009, 12:08 AM
Many thanks for your help guys. You have pointed me directly at the source of the problem and I can now get everything back as it was.
Cheers.
Old 10-14-2009, 12:25 AM
TOM@METRO's Avatar
You are not alone an this one, most all of us have delt with this.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Lost OMF files?? thattheatreguy Pro Tools 9 0 02-16-2012 03:22 PM
Lost WAV files??? theberzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-01-2012 05:01 PM
The Lost Files DJ Moyo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-23-2006 05:42 AM
Lost files and renaming files GoneIndie Pro Tools TDM Systems (Mac) 2 01-13-2005 07:08 PM
help just lost files on mac! tandem Pro Tools TDM Systems (Mac) 3 12-19-2001 11:37 AM
