Digi design pro control Connection to Mac
I got my hands on a Digi design pro control i am currently converting to Pro-tools i am new to the program. How can i connect my Macbook pro running Mountain lion 10.7.5 to the pro control and use it as a daw control surface?? Thanks in advance.
Re: Digi design pro control Connection to Mac
Plug an ethernet cable between them.
To go directly to the computer without an ethernet hub you need a crossover ethernet cable. BTW Pro Control will not work in PT11.
And you probably will need to enable it under Setup>Peripherals
LE could if you copied the profile files from HD
I'll assume 9/10 can use it being a unified installer
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Yes thats what I thought aswell Craig.
If you do NOT have PTHD you need to make sure that you have the two files ProControl_M.bundle and ProControl.Bundle in the Digidesign Controllers folder. PT won't find the Pro Control without these files. ProTools LE does not come standard with these two files. You must obtain them from someone who has an PT TDM rig. If you know someone that has a PT TDM rig, ask them to make a copy of the two files and send them to you. Best Regards Christopher PS. Craig F I edited the post as I wrote a few misleading words
Pro Control works with either version of PT10. Single installer for both versions so the controller files are always installed. Don't know about 9.
Wow thanks for the knowledge guys much appreciated
Pro Tools and Frontier Design Group Alpha Track Computer DAW control | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-12-2011 05:42 AM |
Digi 003 to Control 24 CONNECTION HELP NEEDED | LaReina609 | ICON & C|24 | 4 | 09-26-2008 10:58 AM |
Couple of suggestions for D-Control design | MikeOlson | ICON & C|24 | 4 | 09-07-2007 09:13 AM |
Control room design software | poppy | Pro Tools TDM Systems (Mac) | 5 | 09-01-2002 08:30 PM |
Control 24 and Monitor placement (bad design?) | Robby Hamilton | Pro Tools TDM Systems (Mac) | 10 | 08-22-2002 12:03 AM |
