Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-25-2002, 02:18 PM
JohnGalt JohnGalt is offline
Default Re: Synching analog multitrack/ Tools
You can only use a non-Digi syncbox if
it supports Digidesign 256x superclock.
I use the Midi Time Piece AV and it gives
you the option of either 1x wordclock or
Digi superclock. I used to use a Digi
Universal Slave Driver and the advantage
there is that you can control it from Pro
Tools and the sample rate changes automatically to that of the Pro Tools session. On the MTP AV, you have to manually reset the sample rate and you
also have to be careful that the rate it's
sending to the Digi I/O is the same as the rate of the session. I don't know if the new
HD supports regular 1x word clock though-my guess is that it doesn't.
Hope this helps.
When you once describe a venture as a holy war, you surrender all capacity to judge honest alternatives.
-James A. Michener
Old 02-26-2002, 12:01 AM
Mr T Mr T is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>"is it possible to use "ordinary" syncbox" <HR></BLOCKQUOTE>
Yes. I've done it in the past with a 16 tracks (1/2inches) using a Midiman Syncman (MTC to SMPTE converter). It was definitely what I would call an ordinary syncbox (can't get more ordinary than that in fact...).
The drag was you had to write SMPTE onto the tape (it had to be the length of your session) and, when you stopped and played back in the middle of the song, the soft. (Cubase or PT at that time) would take more than 5 seconds to hook up.
Some music?... http://tmweb.free.fr
Old 02-26-2002, 12:33 AM
Jasse Varpama Jasse Varpama is offline
Default Synching analog multitrack/ Tools
Hi everybody!
I just would like to know that is it possible to use "ordinary" syncbox (for example Unitor 8 or Midi Time Piece) to sync Pro Tools and a analog multitrack. That works fine with my audiosequencer so I can not quite see the reason why I should purchase Digidesign syncbox for that purpose. I'am missing something...
Regards. [img]images/icons/shocked.gif[/img]
Old 02-27-2002, 06:30 AM
Bastiaan Bastiaan is offline
I've succesfully synced an 8-track fostex to protools without any mtc box (except for striping smpte)
this was the setup:
fostex model 80 with time-code on one track, and timecode-synchroniser.
recorded the smpte into protools
fed that track to the "master tc in" on the synchroniser on a spdif output of my amIII card (old dcc-recorder served as d/a converter).
fed the smpte from tape to the synchroniser into the slave tc in.
now protools is the master, and you just connect the channels you need to protools, get all the tracks in, and afterwards you can delete the smpte-audiotrack in protools completely.
What's that?
- That's the machine that goes "pling".
Bastiaan
Pro Tools 10 -- Multitrack Bug?? whatsprotools Pro Tools TDM Systems (Mac) 4 05-09-2012 07:45 AM
Multitrack out with Pro Tools SE mtt78 Pro Tools SE and Essential (Mac) 1 04-17-2012 06:24 PM
synching beats in pro tools with battery djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-09-2008 02:50 AM
synching pro tools to MCI 2-inch analog machine bas1236 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-17-2005 04:19 PM
Analog Multitrack Tape Synchronization dayz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-25-2001 03:59 AM
