Old 05-11-2021, 11:02 AM
Ronan82morgan Ronan82morgan is offline
Default Pro tools outputs out ot sync please help
Hi dudes
I started a song by importing session data (tracks) from another song including the master track. This new master track had a new output name MON L/R instead of 1/2
So then I changed all outputs to MON L/R
But when I recorded bass and guitar they where on output 1/2 and now when I change them to output MON L/R they are out of time delayed slightly. Any idea how I can fix this Please THANKS !!!
Old 05-12-2021, 06:42 AM
Default Re: Pro tools outputs out ot sync please help
Open Setup>IO>Output tab and delete any path you don't want(and you may want/need to rename some). You may also find you have more than 1 path feeding the same physical outputs so do some "housecleaning". Its probably going to take you a few time thru this to really master it, so be patient and give yourself time to learn it. Once you do, things will get better(especially if you find that customizing this stuff can make life easier).
Any session with issues like this may need to be addressed in the same way(this happens a lot if you bring in sessions from another Pro Tools setup)
Outputs configured in I/O setup not available to select as track sends/outputs Stuart@YM Pro Tools 12 5 03-21-2016 07:44 AM
Apogee Duet outputs better sounding than Digi002R outputs? Pasz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 02:19 AM
Pro Tools 8 + 002 = No outputs on 3 and 4 villagechurch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-07-2009 11:25 PM
Pro tools Outputs HELP!!! Infektid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-25-2008 08:30 PM
Kontakt 3 Outputs in Pro Tools LE? smc917 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2008 07:05 PM
