  #81
Old 04-23-2021, 01:11 PM
BCnSTL's Avatar
BCnSTL BCnSTL is online now
Default Re: Eleven Rack Compatibility with MacOS Catalina
Awesome! But now I'm on an M1 Mac - will it work? We'll see!
Update: Doesn't look like it. "System Extension Blocked" - says the developer needs to update the driver.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #82
Old 04-25-2021, 01:23 AM
studiobassist.com studiobassist.com is offline
I just installed the driver on my MBA M1. I didn't get the error message, but the interface wouldn't show up either in my audio preferences, although it does show up in the system information under USB. Where does the error message show up that you had?
  #83
Old 04-26-2021, 06:17 PM
jeffro's Avatar
jeffro jeffro is offline
I don't have an M1 to check, but initial install on my 2019 iMac resulted in similar behavior. I then downloaded/ran the uninstaller from the previous version and ran the new installer again and it worked correctly. I have since been unable to repro the failure with different combos of driver versions so it seemed to be unique to my system (which sees a lot of installs/uninstalls as I'm testing and troubleshooting). Have you tried either running the new installer again, or running the previous uninstaller first?
linkedin
  #84
Old 06-18-2021, 07:20 AM
Daveporter33765 Daveporter33765 is online now
I have tried all the recommended fixes on the earlier thread dedicated to resolving the “Error Initializing Eleven Rack MIDI Engine” error when trying to get Eleven Rack Editor to work.
Is anyone able to utilize the Eleven Rack Editor with the new drivers successfully? If so, any thoughts on how to resolve the error I am seeing?
Thanks!
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1.
  #85
Old 06-18-2021, 07:29 AM
ac30fan's Avatar
ac30fan ac30fan is offline
Thanks!
I deleted Editor app. I then re-downloaded the installer for the version I was on, so that I could deploy the uninstaller provided with that version. Uninstalled. Downloaded app again from AVID. Downloaded most recent installer. Uninstalled again for good measure. Installed latest editor app & verified latest firmware. My 11R was not turned on during any of this. Now I’m golden.
Good luck
2019 iMac 27" 5k Retina
3.6 Ghz 8-Core Intel Core i9
Mac OS 10.15.7 / 60GB RAM
UAD FW Apollo Duo (Thunderbolt Card)
PT 2021.3
Eleven Rack FW v2.00.1 / Software 1.2.14
  #86
Old 06-18-2021, 12:07 PM
Good luck
I replicated your steps with no success. I have a question for you, if you go into your Eleven Rack settings (from the face of the Eleven Rack) to the midi settings, what midi channel is your 11 Rack set to…mine is set for Channel 1.
Thanks!
  #87
Old 07-05-2021, 05:57 PM
BCnSTL's Avatar
Can anyone confirm full functionality on macOS Big Sur (Intel)?
Thanks!
PT 2024.3 Native
  #88
Old 07-21-2021, 07:30 PM
microstudio microstudio is offline
Originally Posted by microstudio View Post
I went a step further and reported them to the BBB and then received a reply from their tech dept saying that "We are currently gathering information regarding the status of the hardware's drivers."
The truth here is this AVID has not updated the drivers for Windows since 2016 and Mac OS since 2019 and they were selling the 11R until 6/13/19.
So a person could have bought a brand new 11R on 6/12/19 and AVID does not give them any driver updates yet. They say they will support the device until 2024 but yet they have not supported it for a long time, this is just bad business and false advertising IMHO.
11R Drivers updated! Well, it might have been my reporting Avid to the BBB that got them to do what they advertised they would do. 2 years without an update and it was only about a month after I reported them to the BBB they got it done....Thanks, Avid!
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
Eleven Rack compatibility options? needled39 Eleven Rack 3 10-02-2017 11:48 PM
Eleven Rack and Ubuntu with Ardour compatibility CeeJayTheFirst Eleven Rack 1 06-15-2015 01:33 PM
Eleven Rack compatibility problems? fastnboulbous Eleven Rack 0 03-24-2011 07:08 AM
Eleven Rack in system settings of MacOS clausiii Pro Tools M-Powered (Mac) 1 12-20-2009 07:15 AM
