Old 12-19-2012, 01:17 PM
soybalm soybalm is offline
Default Re: Multiple regions volume
awesome! I love how the mouse is only focused locally for multi editing but allows you do work on other regions without changing your selection. Pro Tools does it right again!
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 12-19-2012, 01:20 PM
Originally Posted by tj_davies View Post
LOL
Is this not what everyone was suggesting from post one?
Glad you got it working.
Timothy
No one mentioned that you have to have show gain level line showing in order to do this unless I'm missing another method. You can be in wave form view while the gain line is showing and do this. That's the beauty of it.
Old 12-14-2014, 01:30 PM
Boe Larsen Boe Larsen is offline
Hm - probably missing somthing here...
I have two background vocal tracks. I'm in volume view on the tracks. I use the smart tool and drag the selection on the range I want to change. While both selected I move one up 1dB... the other one should change as well, right? It doesn't...
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 12-15-2014, 04:10 AM
joachim's Avatar
joachim joachim is offline
, but will, if those tracks are grouped.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-15-2014, 07:49 AM
Yep, I know. That is needed then?
Boe Larsen
Producer
www.millfactory.dk
  #16
Old 12-15-2014, 08:32 AM
joachim's Avatar
I think, it was always like this (always = my 5 year PT experience, so maybe it was different before).
Dragging only works in the track, where the mouse is, even with a selection made over multiple ungrouped tracks. But at least cutting or deleting breakpoints via "X" or "Del" across selected ungrouped tracks works.
The Ref Guide says : trimming automation breakpoint lines across multiple tracks can be done by grouping. So it looks like it is needed.
  #17
Old 12-15-2014, 08:51 AM
Much easier to just select the clips you want and use the shift-control-up/down arrows to change the clip gain of multiple clips.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
  #18
Old 12-15-2014, 02:40 PM
You're right - unless you want the level to change after the channel compressors...
Boe Larsen
Producer
www.millfactory.dk
  #19
Old 07-24-2021, 07:57 PM
dschtein dschtein is offline
I finally figured this out (for Mac at least).
View menu>Clip>Clip Gain Line
Then, use the grabber tool, but NOT on the clip gain line. Select your regions (again..not near the clip gain line...you want the regular hand symbol). Then you must hold SHIFT AND CONTROL (not Command) use your UP AND DOWN arrows and it will move all clip gains selected in increments of .5. You can't use your mouse or trackpad, as this won't work. Only the up and down arrows, as far as I can tell!
Fades on multiple regions. cosboud macOS 2 03-07-2012 09:49 PM
Wav to mp3 ... multiple regions. How? tpthai2 macOS 4 12-19-2011 10:57 AM
Extending Multiple Regions zwiersd Tips & Tricks 4 04-04-2009 10:23 PM
trimming multiple regions hagai2003 Tips & Tricks 5 08-15-2008 08:18 PM
how to select multiple regions... chris.d Tips & Tricks 2 01-23-2003 09:48 AM
