Structure Yellow GUI, wich one is the right version
I try to install structure Free on my setup ( PT 3 accel HD 8.1 cs2, magma pe6r4, 8 core nehalem mac pro) and i cant make it work. I have the yellow GUI problem, even if i downloaded the latest installer from Avid web site (1.02). The plugin version is 1.0.2.7584. I searched on the forums here and found some posts about this problem but no one linked to a newer version. Which one is the latest version and where do i get it? I also had problems with Air V.I when i installed Pro Tools on my new mac a couple of months ago but i made them work by copying some files from my older system. They would not install correctly with the Pro Tools installer, even after a few try. exept this part (structure), my system is rock solid and i dont want to mess with it (re-installing). Is there a solution? Thank you Luc |
Re: Structure Yellow GUI, wich one is the right version
Hi, I think 1.2 is an older version for PT7 and thats why you're getting the yellow GUI. the latest version is included with all PT versions of 8 and above. so uninstall version 1.2 from the plugs folder and run the PT8 installer again and install the instruments collection which includes structure free. Chris
Can i install only the instrument collection from the installer? I dont remember seing this option. Thanks for your help! Luc |
Yellow Structure | BorleyB | Virtual Instruments | 15 | 02-24-2014 04:23 AM |
Structure LE - Yellow Version | byxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-23-2013 08:41 PM |
Yellow Structure Free - PT 10.3 | grafic | Virtual Instruments | 7 | 12-08-2012 05:29 PM |
Yellow Structure plugin | Oske7 | Pro Tools M-Powered (Mac) | 0 | 06-04-2011 07:42 AM |
Hybrid & Structure are YELLOW in PT9 | spearson8 | macOS | 3 | 04-26-2011 07:36 PM |
