Problems connection MBox 2 to GarageBand
Hello,
I really didn't know where to post this so I'm posting here. Sorry if it's under the wrong thread. Basically, the other day I received a used MBox 2 Pro, along with some ProTools software that's only for the PC. Using a Mac, I decided that the easiest route for me would be to use the MBox with GarageBand, but I'm having a hard time configuring the MBox to my Mac. I installed the proper core drivers from the digidesign Web site, and configured it as instructed in the .pdf file. The MBox is also visible in my System Prefrences under "Other". But my computer is not receiving any input from the MBox, and then I click on the MBox in "Other", it tells me nothing about its firmware, and says "No Hardware Detected". Also, when I open up Garage Band, although it detects my MBox, it is not detecting any audio input from it. Does anyone have an idea as to what I should do? I'm not the best when it comes to computers and such, so I'm at a complete loss. It would be so much appreciated if someone could help, and once again I'm sorry if this thread isn't in the right place and if this question has been asked before. Thank you so much. |
Re: Problems connection MBox 2 to GarageBand
If you go to utilities you'll find the Audio Midi Setup. Open that up and change your default audio ins and outs to the mbox instead of the system card.
Hope that helps cheers |
Thanks for your tip. However, even when I did that, when I go into System Preferences and click on the MBox icon, it says "Unable to connect to Mbox 2"... Maybe my only choice is to run Windows on my Mac? :/ |
MBox Pro 3rd Gen Connection Problems | TheSmackPanda | FireWire & USB Audio Interfaces (Win) | 6 | 05-16-2013 08:54 PM |
*Fixed* my Noise and connection problems with MBox Pro2 | hardhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-09-2010 02:34 PM |
Mbox 2 Pro connection problems | SF_JTRIX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-27-2006 04:35 PM |
GarageBand and Mbox - CoreAudio problems?? | Charlie_OZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-18-2005 10:34 AM |
GarageBand Sample Rate Problems w/ mBox | nikomatsakis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-03-2004 02:33 PM |
