Old 06-15-2008, 03:19 PM
jallen jallen is offline
Default Record Enable via Midi Control change from Controller??
Guys,
I using Pro-Tools LE 7.4 on a laptop for a live performance.
I have three instrument tracks set up. One track for Native Instruments Elektrik Piano, one track for Native Instruments B4 Organ, and one track for a Roland Sound Canvas sound module.
Depending on the song, I may have different tracks enabled or not. Sometimes, I only want the Elektrik Piano, sometimes I only want the B4 etc..
Now, I know to turn on or off tracks, I can simply hit the record enable button in Pro Tools on the lapto, but is there a way to do this via a midi control change or program change via a keyboard controller?? Any suggestions at all would be appreciated.
Old 06-16-2008, 08:00 AM
Default Re: Record Enable via Midi Control change from Controller??
If there is no way to turn on or off the Record Enable button via a Midi Controller..
Then is there an alternative way to turn on or off a instrument track via a Midi Controller?? Thinking along the lines of mute.. or change midi channel, or anything.. I'm thinking mute, would continue to use CPU resources??
Old 06-17-2008, 03:38 PM
original_min original_min is offline
Hi.
This works, but it's the way a girl does it..
Create 3 Midi tracks
Trk 1 midi receives only ch 1 from keyboard
Trk 2 midi receives only ch 2 from keyboard, etc'
Create 3 Aux Tracks....
on Aux 1 insert Akoustik Piano
on Aux 2 insert B4, etc'
Back on your Midi tracks...
Midi track 1 set output to Akoustik Piano
Midi track 2 set output to B4
Put all 3 Midi tracks in record.
Now when you switch between patches/ midi channels 1, 2, 3 etc on your keyboard it will send to the PT instrument that you want.
Yes they are always on, but you wouldn't switch off your hammond between songs at a gig anyway.
I can't get it to change patches for the AP, but b4 patches and all it's controls are all fine from a keyboard controller.
MIDI Record enable behavior DetroitT Pro Tools 10 6 06-29-2013 07:14 AM
How to Record Arm Record Enable using Axiom Pro Hyper Control Cosme MIDI 1 04-16-2013 04:56 AM
MIDI vs AUDIO Record Enable HearInc macOS 4 04-04-2013 03:07 PM
Unable to enable HUI midi controller in PT6.4LE ! CutMaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-26-2004 11:59 AM
Urgent please - Program change won't advance in record enable - please help T-Way MIDI 1 03-31-2001 11:23 AM
