Problems with ASIO drivers, Cubase SX3 with 002r
I have just purchased Cubase SX3 and am trying to get running but it won't come up because it cannot find the ASIO driver. I am running an 002r, with PTLE 6.9. I installed the ASIO driver from my PT 6.9 installation cd as per the recommendation of Digi, and Cubase cannot see it.
I have uninstalled and reinstalled, going one piece of software at a time, PTLE first of course, and still the same problem. Is there something I am missing? Also, by using Cubase (assuming someone can assist me in getting it working - I have tried everything under the sun)will I be free of the latency that kills me in PTLE? I am running WinXP home SP2, Intel® Motherboard - 865 Chipset, 3.0 GHz Pentium® 4 800 FSB Hyper Threading 1MB L2 Cache, 1GB RAM 400 MHz dual channel SYSTEM HARD DRIVE 160GB SATA 8MB cache 7,200 RPM RECORDING HARD DRIVE 160GB SATA 8MB cache 7,200 RPM with a Digi 002r, PTLE 6.9, UAD-1, Command 8, Digimax LT, and hopefully Cubase SX3. |
Re: Problems with ASIO drivers, Cubase SX3 with 002r
Hey Fog,
With Cubase SX3 open. Did you enable it under: Devices/ Device Setup/ VST Audiobay/ master Asio Driver (open the drop down menu and select ASIO Digidesign Driver.) This the same for Nuendo 3 also. Hope this helps. Matt
"To Record Music Is All That Really Matter's!" "When Not Dealing with the Darkside!" Yoda (HOBO MASTER)"I'm Back from the NORTH POLE!" |
When I go there all I have for options is:
ASIO DirectX full duplex driver and ASIO Multimedia driver I know I installed the Digi ASIO driver from the CD... cause I have reinstalled etc. I installed the ASIO driver and the WAVE driver from the CD. |
fog,
When you are doing that..is your 002 powered and a sample rate light lit ? Is PT LE closed ? good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Hey guys,
Thanks for the input. For some reason when I ran a repair (one of many reinstall angles I took) from add/remove it properly installed the Digi ASIO driver and now it seems to be in business. I can playback audio, and PTLE still works and is not broken which is nice. I however now cannot for the life of me to get Cubase to record anything. I have all the inputs mapped correctly etc. I am hoping it is not still an ASIO issue, but I suppose I have worked this to the point where I can take it over the wholly unresponsive Cubase forums. I am so excited about getting out of LE. Just to see the option in Cubase to "process" a UAD plugin almost made me weep with joy. No more time wasted bouncing stuff down to save precious voices and CPU! Thanks again for the help. Great forum here. |
Help with ASIO Drivers for 003 rack - Cubase even not recognise..... | gregers123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-18-2008 05:43 PM |
Cubase not recognizing 002r ASIO drivers | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-15-2006 02:52 PM |
digi001, ASIO drivers, Cubase | Andi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-09-2006 12:13 PM |
anyone using MBOX ASIO drivers with CUBASE/LOGIC? | tom_h | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2003 10:43 AM |
no asio drivers to cubase and a mixer to windows98? | omen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-19-2001 05:39 AM |
