Phase inverted on mixer need opinion!
Hi I´ve got an old studiomaster mixer with nice sounding pre´s but i just relised that the mic inputs have their phases inverted compared to my other individual mic pre´s the ground is 1, hot 3, cold 2!Should I make seperate cabling for these inputs or it doesn´t make any differance?
Re: Phase inverted on mixer need opinion!
Bump!
No sweat.
Mics and cables and mic pres are often enough switched. So simply invert the signal when it makes a difference (ears are good at hearing this). Gunnar.
Gunnar Hellquist true amateur |
It's gonna come out the same way, so unless you're deriving some other output that is either unbalanced or rewired to pin 2 hot, you have nothing to worry about.
Thanks for the replies but what if im using the mixer and other pre´s at the same time? Should I invert the phase of the pre´s to match the mixer or not?
first of all...Hi everyone Ive been off this board for 18 months...Ill post a proper hello later!
As to the phasing issue. In simple terms, as long as you never stereo mike using one mic in each device you shouldnt have a problem. To be safe use the 3 to 1 rule..keep the distance from a mic on one preamp at least three times the distance from one on the other.
Lawrence |
CoreAudio Inverted Waveforms? Out of Phase!! WTF!! | sfere1 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 05-10-2015 07:45 PM |
WOW... Wierd, All recorded audio is phase inverted | Nir Averbuch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-24-2007 03:37 PM |
Sad List of Plugs that don't cancel out when Phase Inverted | 25ghosts | Pro Tools TDM Systems (Mac) | 51 | 08-05-2007 03:00 PM |
What is Inverted Phase? | phatbazz | Pro Tools M-Powered (Win) | 5 | 09-12-2006 12:21 AM |
Phase switch for the PT mixer? | deafguy | Pro Tools TDM Systems (Mac) | 14 | 02-02-2004 01:55 PM |
