  #41
Old 06-20-2019, 11:52 AM
Default Re: Increase in PT performance going from 32GB RAM to 64?
AHCI/NVMe make little to no difference in cheesegrater and trashcan because of PCI 2.0 speeds but currently you have lot more choice and bigger capacities with the newer NVMe compared to older AHCI which are no longer even manufactured as far as I know
  #42
Old 06-20-2019, 02:30 PM
Yep it is all about being to use the latest/current SSD drives. NVMe is more efficient that AHCI. Designed exactly for what Flash etc needs... actually its roots go back to work by Intel to support what eventually became Optane (not actually based on Flash). AHCI is some old old stuff.
  #43
Old 06-27-2019, 01:23 PM
skizzo skizzo is offline
i personally don't see an added value for BOOTING with a NVMe SSD vs 2.5" SSD.
now if you want to take into consideration their respective read/write speeds then that is where all the added value is for using a NVMe SSD vs 2.5" SSD
they are night and day performance wise there but if you don't need the additional read/write speeds it's not a good upgrade/change in my mind
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
  #44
Old 06-28-2019, 05:56 AM
K Roche's Avatar
K Roche K Roche is offline
I am no tech but isn't the session to RAM storage feature run on the Boot drive? And would that not make the increased read/write speed with PCIe SSD boot, more desirable ?
System :
Enjoy the Journey
.... Kev...
  #45
Old 06-28-2019, 08:29 AM
BScout BScout is offline
No. The session to Disk Cache (RAM) takes place where ever the session Audio files are stored. It isn’t dependent on the boot drive (unless the session files are stored there)
  #46
Old 06-28-2019, 08:50 AM
Howardk Howardk is offline
Originally Posted by arche3 View Post
This is madness. My 5:1 keeps going and going.
Sent from my SM-G975U using Tapatalk
Yea, the best computer ever IMO!
...for system configuration info see my profile
(Click on member name)
  #47
Old 06-29-2019, 06:44 AM
K Roche's Avatar
I did not know that, thanks. So given my system (below) would it make sense to replace the original PT session and FCPX storage spinner hard drives and put some 2.5 SSDs in those sled thingies that go in the hard drive bays ?
System :
Enjoy the Journey
.... Kev...
  #48
Old 06-29-2019, 07:11 AM
Replacing spinners with solid state always makes sense if you have the budget
  #49
Old 06-29-2019, 08:23 AM
K Roche's Avatar
Thanks, one more question as per my system I currently have the Samsung 951 ACHI PCIe Boot Drive. While I do have one more PCIe slot in my Mac Pro the (4th/top one) but am I correct in assuming I can't or should not try, to mix ACHI and NVMe given it seems that ACHI is no longer available in 500 - 1k GB options.
System :
Enjoy the Journey
.... Kev...
  #50
Old 06-29-2019, 10:34 AM
As long as you don't try to RAID them together I don't see a problem in having AHCI and NVMe drives living happily together
Performance hit in 8.0...or increase? Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 46 01-02-2009 03:07 PM
Does lot's of RAM really increase performance? bassmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-03-2002 01:18 PM
