Old 02-05-2014, 03:21 PM
Markrosoft Markrosoft is offline
Default Artist Transport not working with PT11
Hi everyone. I recently updated to Mavericks (on a new computer) and Pro Tools 11. I was coming from an old MacBook Pro running Snow Leopard and Pro Tools 10. My Artist Transport worked great but now it's not working at all with Pro Tools.
I have the most recent version of EuControl (3.1), I've turned off app nap on EuControl and Pro Tools and the transport actually works with itunes. So the computer is definitely seeing it.
When I launch Pro Tools the screen on the Transport says "Pro Tools 11Mac" but none of the buttons work. So I launch EuControl and try to re-map all the controls but that doesn't work. Say I try to map the top button above the wheel so that it acts as "Play" - I highlight it in EuControl, click command, click add, select wheel but then the only option on function is "TEST." Normally it has a slew of transport and scrub functions but there are none at all now, so I can't select play like I should be able to. If I want to map another button to a Eucon command and I select Eucon in the "Add..."-prompt and the details panes (where all the commands should be) are empty. So there's no way to assign functions and every single button is un-mapped for pro tools. But again, it works fine with iTunes.. so clearly the Eucon IS connecting properly.
I see that a lot of people are having a lot of issues with the Mix and the Control but my transport is just straight-up broken when it comes to Pro Tools 11 and haven't seen anyone with this issue. I was wondering if anyone has an Artist Transport working on Mavericks and/or Pro Tools 11. It's hard for me to tell if this is a Pro Tools 11 or a Mavericks thing because I had to switch to both at the same time. Any tips or info would be much appreciated!
Old 02-05-2014, 03:47 PM
Southsidemusic's Avatar
Default Re: Artist Transport not working with PT11
4 units including Artist Transport working great here Mavericks 10.9.2 and 10.8.5 and EuCon 3.1. Macbook Pro Retina computers 2013.
All via WiFi from Internet Modem and wireless into macbooks.
Best Regards
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Artist Mix Not Working in PT11? Chingy Pro Tools 11 9 07-01-2013 10:56 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
ARTIST TRANSPORT: Transport knobs do not light up when pushed smallchamber Artist Series 0 02-26-2013 05:36 AM
Artist Mix + Artist Transport soundsled Artist Series 1 09-06-2012 09:17 AM
Using Artist Control with Artist Transport? GrievousAngel Windows 2 03-14-2012 03:29 PM
