Old 02-24-2007, 10:38 AM
Johnny Cadelco Johnny Cadelco is offline
Default Compression & Reduction
Sup... I have two questions:
How compression should be used on drums, kick and the master fader? In terms of ratio
When I do use compression on drums, how much reduction should be taken off? -5db or less?
Same thing for the master, how reduction when using compression should be taken off?
thx guys any feedback i'd appreciate
Old 02-24-2007, 01:23 PM
The-Jackyl The-Jackyl is offline
Default Re: Compression & Reduction
It is really just personal preference...I just use it until I get the sound I am looking for.
Old 02-24-2007, 02:37 PM
Naagzh Naagzh is offline
For starters, reducing by any more than a few dB on the snare will likely bring out hi-hat bleed. Maybe start with 2:1. And if your drummer is consistent, then you may not need any at all. Just enough to even out the dynamics a small amount, don't flatten it. The same could go for the kick. On all the drum tracks, playing with the attack and release times can get you some different sounds.
Watch the free Kenny Goia tutorial on parallel compressed drums here. Note the settings he uses on the compressor. There's more to this technique than he demonstrates, but it's a good start, and you can't beat the price!
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Hiss Reduction Noice Reduction advision205 Tips & Tricks 8 03-04-2010 03:44 PM
hiss reduction newie General Discussion 11 08-30-2008 05:24 AM
Hiss reduction TaylorT Tips & Tricks 6 10-29-2007 05:07 PM
Noise reduction ChattyJ Post - Surround - Video 4 09-08-2006 01:55 PM
hum reduction tips LarsRec Tips & Tricks 1 04-10-2001 09:11 PM
