Synchronization software for backing up to hot-swap removable firewire drives...
I have been using Granite Digital hot-swap firewire drives (http://granitedigital.com/catalog/pg...tswapdrive.htm) with much success. I consistently recorded 32-34 tracks at 96k 24 bits onto one 120gB IDE drive in these hot-swap cases without issue for 2-3 hour shows last fall. Since shows were often more than 100gB I decided to back them up to another removable hot-swap firewire drive. No complaints thus far - it has worked well.
I have been using a program called Synchronize! to keep the backup drive up to date with the master drive. Does anyone else do something similar and use synchronization software? Scott |
Re: Synchronization software for backing up to hot-swap removable firewire drives...
Yup!
I use synchronise too! It's nice and simple and does the job. Ray |
If your looking for a solution of OSX, check out http://www.softobe.com/products/flsy/pp.html It works GREAT for copying files and folders from drive to drive.
I use Connectix Copy Agent.
Bryan Jackson Independent Audio Systems Engineer Burbank,CA / Las Vegas, NV |
I love the "SmartReplace" function of CopyAgent. Too bad is won't work on OSX.
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
I used to use CopyAgent's SmartReplace feature too. I recently switched over to FWB's Backup Toolkit. It's OS 9 and X compatible.
Has Digidesign fixed the all time bug with removable drives yet? | Logic Pro | General Discussion | 26 | 02-01-2010 06:15 AM |
Cannot eject removable drives while running PT | Stephen Webster | Post - Surround - Video | 5 | 06-22-2007 07:45 PM |
Panther/Atto new driver with removable drives | Wolfgang Eller | Pro Tools TDM Systems (Mac) | 2 | 03-22-2004 11:36 AM |
Mounting removable scsi drives in OSX | schiffdigital | Storage Subsystems | 2 | 05-24-2003 09:46 PM |
Hot Swap Firewire Drives & PT | RMD | Pro Tools TDM Systems (Mac) | 2 | 06-22-2002 01:32 PM |
