Help with Focusrite setup
Good morning. I thought I was passed this problem but it's back! I have 2 interfaces hooked up to my pc. A Scarlett 2i4 and a project mix I/O. Now when I try to use the 2i4 I get a pop up that says "Problem with clock source". "Check session parameters"( I assume they mean bit depth and sample rate, etc.) These are the same settings I always use, 24 & 48. I have not changed anything on this session since I last saved and closed it. If I use the Project mix to open the same session, once I enter the proper info for that I/O the session opens and plays back. How can I get around this issue once and for all? Thanks.
Re: Help with Focusrite setup
Usually in the interfaces (2i2) control panel there is a place to select the clock source, but looking around the internet I don't see that option for that device. You would probably want it set to internal, if you see an option for that.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Focusrite Pro 40 setup problems | chrislewisdrums | macOS | 2 | 11-29-2012 05:07 PM |
Focusrite ISA One Setup w MBox One S/PDIF Connection | Quinn9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-31-2011 08:56 AM |
M-Box set up help connecting with Focusrite ISA Digital One Setup Please HELP | CaptnAwesomee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-29-2010 06:14 PM |
M-Box set up help connecting with Focusrite ISA Digital One Setup Please HELP | CaptnAwesomee | Pro Tools M-Powered (Win) | 2 | 11-29-2010 02:49 PM |
Focusrite Liquid Mix - Mac - 2626- Firewire/setup questions... solutions? | cueball73 | Pro Tools M-Powered (Mac) | 5 | 11-12-2010 10:46 AM |
