Old 07-18-2011, 01:32 AM
vieris vieris is offline
Default Best way to compensate for REC input latency?
What is the best way to compensate for REC input latency/offset? Every A/D and or audio interface software creates a small REC offset.
Most DAW's have a place to enter in a sample/ms offset amount. How do I deal with this with PT9?
"Any experiment of interest in life will be carried out at your own expense."
Old 07-18-2011, 02:05 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Best way to compensate for REC input latency?
I have not heard about rec input offset.
Are you not talking about input monitoring latency ?
Old 07-18-2011, 05:41 AM
No, input offset. (time aligning i/o).
If you record a loopback of an output back into an input & zoom into see how far off the wavform/offset is from the source, this is your "input latency offset".
Everything you track/rec is off by this amount. Most DAW's have a manual offset. Can't seem to figure out a way to do this in PT.
Old 07-18-2011, 06:25 AM
chrisdee's Avatar
Ok.
Im not completly shure it's what your looking for, but there is something about Hardware Insert Delay Offset on page 962 in the Pro Tools Reference guide.
Setup-> I/O -> H/W Insert Delay
Old 07-18-2011, 07:35 AM
More info might help here(like what interface and what buffer setting you run at while recording). Small amounts of offset, like 1.2ms(the average time for conversion between analog to digital and back) are no more serious than the physical distance between 2 players in a large recording space. Are you having a problem?
[IMG] code is Off
How to compensate for analog summing mixer hardware latency? ryanstewartguitar Pro Tools 10 12 08-23-2020 01:37 AM
Does PT LE Compensate for plugins latency OR NOT? How much!? Retinal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-08-2008 07:39 PM
Can you compensate for latency with outboard send effects? bukman Tips & Tricks 4 10-05-2007 06:29 AM
Nudging a track to compensate for FX latency? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2007 10:08 PM
Does HD compensate for latency WRX07 General Discussion 6 10-10-2005 02:35 PM
