Old 09-23-2005, 12:56 PM
All Ears All Ears is offline
Default iTunes Conflict
Sorry I'm reposting, the DUC won't let me reply to a previous thread. My problem is actually with iTunes, not Pro Tools. Ever since I upgraded to iTunes v 4.9 it won't open. The guys at Apple suggested that it may be a conficlt with my Digi Hardware, but they wouldn't say more than that. Again, Pro Tools works fine. I have since upgraded to iTunes v 5, same thing. When I go back to v 4.8, it works, but I really need to get v 5 working. I have turned off all my digi hardware and set all sound options to internal, still not luck. Any ideas?
PowerMac G4
OS 10.3.9
Mix Plus System Running 6.4.1 with 1 888 and a USD
Quicktime 7.0.2
Old 09-23-2005, 01:02 PM
Seeee Seeee is offline
Default Re: iTunes Conflict
try uninstalling or reverting back to the quicktime 6 whatever. just try it.
theres a reason they make a special uninstaller for it and digi on here said that qt7 is a problem with digi stuff. whether thats at the hardware level, I dont know. did ya run a repair of your disk permissions? try that. also, create another user profile and log into it and see if the problems still there. sorry to hijack your thread with QT7 suggestions buty it's all i have to suggest.
Old 09-23-2005, 03:46 PM
No problem, I appreciate the suggestions. Unfortunately I have tried all of the things you have suggested (except for reverting to QT 6, which I will try now). But I am still wondering if anyone out there ahs experienced any type of conflict with older PT versions and newer iTunes versions. Again PT is fine, only iTunes dosn't open. Thanks.
Old 09-23-2005, 10:08 PM
masaudio masaudio is offline
Yes I have the same problem. I use PT 6.4.1 and OSX 10.3.9 running MIX24 3.
The only way it will work is if, you have the PT appl. open and then you open ITunes (I have ITunes 5). I has to be a bug!
Old 09-24-2005, 12:13 AM
Keith Moore Keith Moore is offline
I had the same problem, it all went away when I updated to Tiger.
Pro Tools HDX 2018.1.0
Lynx Aurora 16
Ross Martin PCM4222
Ross Martin Super Beast
Apple Mac Pro 8 Core 2.66Ghz 16GB RAM
OSX 10.11.6
http://www.keith-moore.org
Old 09-29-2005, 01:29 PM
Sonny Keyes Sonny Keyes is offline
I had the same problem as a result of an ill-advised upgrade to 10.3.9 and QT7. I used the Apple reversion software to go back to QT6.5.2 but the problem persisted, and wouldn't go away until I reverted to a clean install of 10.3.5 and upgraded to 10.3.8. (after having blown away every vestige of Quicktime)
It has to do with the Digi Core Audio Driver which iTunes, Quicktime and the System use to route audio to your Digi hardware. As it turns out, Digidesign have *never* supported 10.3.9, and now that we're well into the 10.4s, likely never will. So your options are to go forward or backward, system-wise.
Sonny Keyes
Ricochet Post
Toronto
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Old 09-30-2005, 09:16 AM
trackattack trackattack is offline
Having same problem now, after an ill advised attempt to upgrade Quicktime to 7.0.2. Quicktime first was effected, then Itunes, then when I de-evolved to QT 6.5 nothing happened. I re-installed the OS (10.3.9) and Pro Tools 6.4.1 took a dive. Unexpected quits when trying to boot it up. Nothing has worked so far to fix it. I think the post talking about Quicktime/Itunes and the Digi audio core is correct. Going to try a clean install of the OS and PT now. Any suggestions?
Old 10-04-2005, 10:59 AM
Make sure you first get rid of anything Quicktime-related ANYWHERE on your boot disk. As I mentioned before, the reversion software (QT7->6.5.2) doesn't actually get rid of whatever it is that buggers up DCAM. And don't re-install 10.3.9, stop at 10.3.8, as Digidesign doesn't support or recommend 10.3.9. HTH
Sonny Keyes
Ricochet Post
Toronto
Sonny Keyes
Toronto
Old 10-07-2005, 08:45 PM
hellofargis hellofargis is offline
man this is weird. so I'm in the same exact situation (10.3.9, itunes 5.0.1, PTLE 6.4, and QT 7). here's my report: if you open PTLE first, then open iTunes, iTunes works (even after you close PT). but you cannot open iTunes first.
i'm calling mac tomorrow. I'll update you guys if I learn anything.
Itunes conflict? thepurpleroom Pro Tools TDM Systems (Mac) 2 03-04-2008 06:04 PM
iTunes conflict All Ears Post - Surround - Video 4 09-30-2005 10:31 AM
iTunes Conflict All Ears Pro Tools TDM Systems (Mac) 4 09-23-2005 08:01 AM
ProTools and iTunes conflict? bigcow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-11-2005 09:30 AM
iTunes/Pro Tools conflict w/ XP? drewp2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-25-2005 08:56 AM
