Old 09-20-2020, 11:28 AM
tripstation tripstation is offline
Default D-Control Probs
My D-Control seems to be stuck in Dim mode?
I have to have the main monitor knob all the way up to zero just to compensate.
Any ideas.
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 7
Ableton 9
Avid Omni HD
Avid 8*8*8 HD
D-Control ES 32 Channel
Native Instruments Maschine Studio
PowerCore *2
UAD-1
Universal Audio 1176 LN
Universal Audio 2-LA-2
Neve DPX
Supermicro X10DAX Dual Xeon E5 v4 Win 10 64 128GB Ram
Old 09-21-2020, 10:52 AM
Pete Gates Pete Gates is offline
Default Re: D-Control Probs
You can, as a temporary fix, turn the Dim Level to zero, then the monitoring level knob will be at its nominal setting.
Can you switch monitoring sources etc? Is the D-Control otherwise happy with comms to the X-Mon? LED flashing on the X-Mon?
You can try resetting the X-Mon and re-downloading the software to it: hold the Mute button on the X-Mon as you power it up then on the D-Control if you go into the firmware version pages I think it is, you can update the firmware from the factory flash backup.
Good luck,
Pete
Old 09-21-2020, 12:52 PM
HI Peter,
Yes that's what I'm doing, having the Dim level set to 0.
Comms with the X-MON seem OK.
Lights flashing etc.
Will maybe try the reset thing.
Thanks.
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 7
Ableton 9
Avid Omni HD
Avid 8*8*8 HD
PowerCore *2
UAD-1
Neve DPX
Old 09-22-2020, 11:50 AM
Hi Peter,
I tried holding the mute button down on the X-MON.
The behaviour is the same.
Also both the talkback buttons stay on permanently.
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 7
Ableton 9
Avid Omni HD
Avid 8*8*8 HD
PowerCore *2
UAD-1
Neve DPX
Old 09-24-2020, 03:22 AM
Hi Peter,
thanks for all your tips.
You led me to thinking about the reset thing.
I simply went into the Utility menu on the D-Control and pressed reset.
That solved issue.
Thanks.
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 7
Ableton 9
Avid Omni HD
Avid 8*8*8 HD
PowerCore *2
UAD-1
Neve DPX
2 mbox probs: mix control switch + latency, help! psforza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-15-2005 03:14 PM
SP2 M-box probs... Eloquist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-25-2005 05:56 PM
192 I/O probs Peter Duemmler Pro Tools TDM Systems (Mac) 5 03-14-2004 05:02 AM
Digidesign Control Panel probs.. Sound Works UK Pro Tools TDM Systems (Mac) 5 04-22-2001 02:18 PM
Probs Interval Pro Tools TDM Systems (Win) 4 05-08-1999 12:48 AM
