Old 03-06-2010, 12:31 PM
El Rico El Rico is offline
Default Solid State Logic Listen Mic Compressor
I recently bought the Fxpansion VST to RTAS adapter, very useful indeed !
Then I downloaded the free VST plug-in LMC-1 from Solid State Logic but I can't find it into Pro Tools. Does anyone have a clue ?
Old 03-06-2010, 01:13 PM
necjamc necjamc is offline
Default Re: Solid State Logic Listen Mic Compressor
I am eagerly awaiting an answer as well. I downloaded that today, and have not yet purchased the wrapper. Do you have to manually pur the wrapped plugs into the plug in folder?
Old 03-06-2010, 04:51 PM
sunburst79 sunburst79 is offline
Its been a LONG time since I used the wrapper but you need to fire up the wrapper and wrap the plugs before they will show in Pro Tools. There should be a column in the wrapper that shows which plugs have been sucessfully wrapped. If you not seeing it chances are its not wrapped and won't show up in Pro Tools.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-07-2010, 08:27 AM
Ok,so this is from SSL website in the FAQ section:"Why can my VST software not see the SSL Plug-in?"..."During the install you will be asked to give the plug-in a path to install to.The install program creates its own 'Solid State Logic' directory which can mean that VST can't find the plug-in file. For the plug-in to work you will have to manually copy the LMC1.dll file back out of the SSL directory and into the same directory as all the other plug-in.dlls".
I check this out and will let you know ;-)
Old 03-07-2010, 10:03 AM
And the Looser is.................ME !!! Unfortunately, the wrapper says it's not a valid plug-in and don't wrap it. What else should I do now?
Old 03-07-2010, 05:02 PM
JazzyJ JazzyJ is offline
Macintosh computer with PowerPC G4 or faster processor (not Intel Mac)
http://www.solid-state-logic.com/Music/LMC-1/index.asp
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 03-08-2010, 12:24 AM
Thanks dude, that had not occured to me !
Solid State Logic Nucleus zedhed Pro Tools 9 0 02-20-2011 04:19 AM
OMG: Mackie buys out Solid State Logic Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-16-2004 05:37 AM
Solid State Logic (SSL) Daniel_Isaiah Pro Tools TDM Systems (Mac) 13 01-31-2003 10:56 AM
Solid State Logic (SSL) mixing... Daniel_Isaiah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-27-2003 11:08 PM
ProTools and Solid State Logic Alliance??? scoobdaproduca Pro Tools TDM Systems (Mac) 13 01-02-2003 07:47 AM
