Old 07-09-2007, 01:22 PM
Omar Rodriguez G Omar Rodriguez G is offline
Default ignition pack 2 a big lie?
many of the plugins who come included in ignition pack 2 do not work.
for example:
The limited versions of IZOTOPE (trash lite, spectrum lite, ozone 3 lite) only can be used only one time, each of the presets. To the following time that you them try to use they do not turn out to be available.
The Timew arp 260, even installing the drives of update that are available in the web of digidesign, it does not sound.
Then, what is what the buyer acquires really? not at all?
If there is someone to whom these plugins him have worked correctly, might I to say how it did it?
Thanks.
omar.
Old 07-09-2007, 01:31 PM
spkguitar's Avatar
Default Re: ignition pack 2 a big lie?
Read that again carefully, paying attention to the red highlighted text. You are complaining about the limitations of the limited versions of these plugins. The plugins still function, and you are able to test them out so that you can decide if you want to purchase the full versions, but they are still limited (There's a reason they were free, right?)
There have been a few other complaints to this effect. I don't have it, so I can't offer a direct solution, but I have a suggestion for something to try; select a valid hardware audio input on the track where you have it inserted.
Old 07-09-2007, 04:54 PM
Thanks...
Old 07-10-2007, 03:40 AM
Jamtime Jamtime is offline
Thanks...
Hey! U got the TimewARP to work? How? I also inserted a proper HW input but still no sound??
/Micke
I voted at www.deardigi.com
Drummer of Yamaha Birch Absolute Custom Nouveau Vintage Natural - Zildjian K Custom Dark - Sabian HH
Macbook (2009-01) 2.0 GHz 4 GB
Intel Quad (2007-07) Q6600 2x250 4 GB
PT 8
Digirack 002
Monitors: JM-Lab Electra 906 & SW900 driven with Pioneer Reference M-90
"Semiprofessional user"
Old 07-10-2007, 12:38 PM
540s 540s is offline
I did have some trouble getting the stuff to work but it does. I dont think I did anything special... especially since I'm just getting into my first PT system myself & barely know what I'm doing.
I first loaded everything from the discs at one time & found myself a little overwhelmed.
I know I had problems with Timewarp LE & had to reinstall it a couple times but it works. I think the problems were the way I was trying to set it up though. Once I had BFD Lite & Expand working with my Axiom 25, when I went back to check out Timewarp LE it was working.
Can you use other instruments with your controller & it's just timewarp thats not working or are you having problems wiht all the instruments?
Re the Ozone stuff. Yes they are limited versions but theres no reason you can only use them once. I have sessions with multiple spectrons & even ozone 3's running wiht the same presets. They are italicized in the menu as if they were not available when they are opened the second ( or more) time but still work if you click it. (at least on my system) Its a bit annoying only having the few presets though. I will be buying the full versions of Ozone 3 & probably spectron very soon as I like those two alot.
Old 07-10-2007, 03:35 PM
Oh yes! Everything else (lots of plugs) works excellent! Ive installed wARP like 5 times and the update 2 times. It just wont sound..
And actually Im a bit tired of these very limited apps and Im not so intrested of wARP anymore. Though I think Arturias Analog Factory SE is a very good component in Ign pack.
/Micke
PT 8
Digirack 002
ignition pack 2 tracktensionrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-12-2011 05:28 AM
Ignition Pack 2 spidey901 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2007 09:30 AM
IGNITION PACK 2 what about us?? BlueWeed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-05-2007 12:30 PM
Ignition pack HardKnocks Pro Tools M-Powered (Mac) 0 05-23-2006 04:04 PM
Ignition Pack tangleword Pro Tools M-Powered (Win) 1 04-28-2006 05:29 AM
