methods to reduce sample rate of session in progress?
Hi all,
I was give a session at 96000 Hz and now that I am well into it, my computer is having trouble keeping up. What would be my options to reduce down to 44100 Hz, while preserving all my work? Many thanks for any help and suggestions. |
Re: methods to reduce sample rate of session in progress?
File menu > "Save Copy In..."
Choose the sample rate you want and select all items you want to copy.
Haha.....but seriously, I would go to 48k
Great! I'll give that method a shot.
Ok, I guess I can afford 4800 Thanks all |
Curious as to why? If your final distribution format is 44.1KHz, you may as well go to that now (if your system can't sustain the higher sample rate). The higher sample rate 'quality' discussion is a rich (fraught!) debate but there's no benefit of 48KHz over 44.1KHz with modern systems.
(I'm ignoring JuanPC, he has nothing useful to contribute). Cheers, Pete |
Pete |
Regardless, what I was failing to convey - to the OP, not you - was, if you have to downsample from your acquisition format go straight to your delivery format, I wouldn't recommend also having an intermediate format. If he doesn't have any particular delivery format then 48KHz is obviously fine!
Cheers, Pete |
Hi: if you have 96KHz media, the safest way should go down to 48 KHz, then on the mastering stage you can safely do another SRC to 44.1 KHz if that's the final format.
44.1KHz CD 48 KHz Video 88.2 KHz HiRes audio 96 KHz HiRes video And so on up to 11 MHz DSD
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
Session sample rate and clock | stevegalante | Pro Tools TDM Systems (Mac) | 2 | 03-26-2013 08:39 AM |
Way to Convert Session Bit/Sample Rate??? From Within Session??? | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2011 09:48 AM |
Sample Rate Not Changing With Session | Siegfried Meier | Pro Tools TDM Systems (Mac) | 1 | 04-28-2010 08:23 AM |
session sample rate HELP | sonora | Pro Tools TDM Systems (Mac) | 10 | 10-03-2005 06:35 PM |
anyone up for a sample rate 96 in a session?? | AM STUDIOS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-08-2005 04:05 PM |
