Old 04-23-2018, 02:36 PM
belolab's Avatar
belolab belolab is offline
Default HDX drivers not available outside of Protools 18
Been having this issue for a while. I can not select the HD drivers for any application other than Protools. Am running El Capitan and 2018.4 HD with HDX card on 2010 6 core mac pro.
So I decided to upgrade to a new SSD and have done a fresh install of everything. For a while the HDX outputs showed up as available in MacOsx audio/midi setup app, and when I shut protools all was normal. Now I am back to there being no HDX in Audio/Midi setup, and when protools shuts my converters (lynx aurora 16s) switch to 192khz and distort.
Anyone else seen this? Weird that it came right for a while with a fresh install then reverted.
Any ideas? Is pretty boring as can fire white noise thru to artists if protools crashes
thanks
Old 04-23-2018, 09:17 PM
belolab's Avatar
Default Re: HDX drivers not available outside of Protools 18
Got it! So I have to toggle off the HDX in protools to be able to use HDX in other DAWS. Noticed that Protools takes the HDX outputs back when reloaded, even if it is still set to use a different interface!
Bloody confusing, but workable
Old 05-10-2018, 04:43 PM
belolab's Avatar
Nope, worked once, and hasnt worked again. Have reinstalled etc.....this is a realy pain
Cant open Protools - are there 9.0.1 specific drivers? writeroxie Pro Tools 9 1 01-07-2011 08:21 PM
USB midi drivers do not function in protools 8.0.1 dnkygirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-06-2009 02:27 PM
Drivers, I want to use both protools and cubase.. broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-16-2008 09:50 AM
Delta drivers, before and after Protools... funkgypsy Pro Tools M-Powered (Win) 0 01-17-2008 09:15 AM
protools drivers for other cards! jayq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2005 01:01 PM
