#501
Re: Best System for PTLE for under $1000.00
Allen,
XP2200 is on my A7M266, volcano 7 installed as well...but i'm totally confused about the power supply thingy. all instructions say to connect the 3-pin connection to the cpu_fan, but the volcano has 3-pin with only 2 wires in it(black and red) and a 3-pin with only a yellow wire in it...i want to use that extension to control the fan as well and i don't know what to do. i've ran the red/blue to the extension, what do i do with the yellow coming out of the fan...put that onto the cpu_fan? and what do i do with the yellow that's coming from the extension piece? this sounds terribly confusing so i hope you just remember doing it yourself and what you did exactly. people reading this must think i'm an idiot!
i love apple. i love lamp. |
#502
Allen [img]images/icons/wink.gif[/img] |
#503
ok well there's 3 wires coming out of the volcano, red blue and yellow. the red and blue go into a 3 hole clip, leaving one empty. and the yellow wire goes into another 3-hole clip, leaving 2 empty. then the red-blue clip goes into another clip with 3 prongs in it (red/blue/yellow wires)...this is the extension piece with the 3-stage selector (i'm starting to lose myself). ok well the red/blue wires connected to the prongs go into the selector switch, come out the other side and go into the power clip/connector, filling 2 of 4 holes. the yellow clip connected to the prong goes into another 3 hole clip, leaving 2 empty. wow i must have you really lost. do i need to do anything to the yellow wires, and does nothing connect to the cpu_fan on the motherboard? allen i'm sorry, this is probably a headache for you
#504
That yellow wire has to be for fan control monitoring. I wouldn't worry about it if you don't hook that up.
#505
Thank you! one more question, promise controller goes into slot...and the 2 harddrives connect to it? and i plug cd-rw into primary IDE on the motherboard?
#506
#507
Let me know when you get it booted. Allen [img]images/icons/wink.gif[/img] |
#508
thanks again, you're a life saver here. now i'm connecting the leads onto the MB...what differenciates which wire is the ground? i know that between red and black, black is the ground and red is the +5...but what about all the other colors, some combos are green/white, blue/white...argh. let me know if you want me to stop hassling you
#509
Allen |
#510
ok i'm done with the fan, thank you very much. i'm connecting those things into the motherboard like POWER LED and reset and all that jazz, and there's a whole bunch of colors. which is the ground for the wires? is there a rule of thumb
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
