Old 07-22-2022, 11:25 AM
CHRIS AIKEN CHRIS AIKEN is offline
Default Re: Hybrid Engine/ DSP Mode latency issue
Originally Posted by matt mahaffey View Post
I run dense sessions but have to enable the Hybrid Engine to overdub constantly. As soon as i turn Hybrid off, my audio is misaligned. I have found that if i simply click "Setup" and then "Playback Engine" and close the window having changed nothing..... everything aligns back properly. Talk about a ghost in the machine. Try it instead of relaunching the session, might save you some time!
Yes it's not fun when the talent is ready to do another take and you have to "fiddle" with the system to get to play properly.
I had a new one the other day. While tracking players live...playback through the speakers was fine. In there headphones things were delayed and all over the place. I had to restart the session and then it worked as expected.
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 07-22-2022, 01:09 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Totally fair comment.
We actively track the number of cases associated with bugs. Bugs with higher cases counts tend to get prioritized higher.
I can champion for this to be fixed internally, and have been, but there are always bugs to be fixed and it is always helpful to have your voices formalized and counted in a case.
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 07-22-2022, 06:27 PM
Default Hybrid Engine/ DSP Mode latency issue
m
Ok thanks for giving some insight.
Obviously it’s a very corporate way of looking at a problem in a business... squeaky wheel gets the grease.
Maybe you could stress to them the severity of this...it’s not like most bugs that are a slight inconvenience.
It really makes you look bad in front of clients when their performance plays back in a different way than they laid it down.
. I’ve never had an issue that made me want to stop using an avid product in my over 20 years of TDM/HDX systems.
I’ve seen a couple people get rid of their Carbon over this.
I’ll do the same if it’s not sorted sooner than later.
Not that I want to but this negative is starting to out weigh the positive of the product for me.
I’ll submit a support ticket to help roll things along.
Old 07-31-2022, 12:20 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Interesting workaround. Maybe it works that way with Carbon as well.
Old 08-03-2022, 02:50 AM
Boe Larsen Boe Larsen is offline
I experience this issue also. It's sort of the core of what this system is suppose to do. Not a really pro tool...
Boe Larsen
Producer
www.millfactory.dk
  #16
Old 08-13-2022, 01:32 PM
blastula blastula is offline
Workaround: De-activating and Re-activating the track puts it back in sync.
  #17
Old 08-31-2022, 11:33 PM
SoundReplay SoundReplay is offline
Same issue here. Using Pro Tools Ultimate 2022.7.
Recording drums with 10 enabled DSP track, all goes well. When deselecting the DSP mode, the drums are completely out of sync with the rest of the track (weird delay is being introduced, so it's not just the 10 tracks out of sync with the rest of the song).
Anyone has the correct procedure to open a case at Avid? Thanks!
www.soundreplay.com
  #18
Old 09-01-2022, 03:51 AM
dominicperry dominicperry is offline
https://my.avid.com/sso/Salesforce
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #19
Old 09-01-2022, 03:53 AM
It's worth raising tickets with Avid. They fixed a specific problem I reported with Carbon, just for me!
Dominic
  #20
Old 09-01-2022, 04:39 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Dominic
YMMV, none of the issues I reported in the last 4,5 years have been fixed. Not one. All are logged as a bug, case closed without a fix. Some are still causing major issues for us.
Nice to hear others have better experiences though.
Hybrid Engine vs Non-Hybrid HX|2 in Post. minister Post - Surround - Video 6 12-27-2021 03:41 AM
Hybrid Mixer and HDX - need a separate "mixing" high-latency DSP mode for tracks Skwaidu Pro Tools 2 10-24-2021 08:51 AM
HDX Classic / Hybrid engine low latency bus routing question RobertDorn Pro Tools HDX & HD Native Systems (Mac) 7 09-30-2021 02:11 PM
The Hybrid Engine LDS Pro Tools HDX & HD Native Systems (Mac) 64 07-31-2021 09:17 AM
Low latency mode issue in Pro Tools 10, has it been sort out? Gary Gould Pro Tools 10 6 01-29-2015 05:16 AM
