Old 04-17-2016, 11:39 AM
tnipe tnipe is offline
Default Waves plugins and could collab
Anybody managed to get cloud collab working properly with Waves plugins? When I'm making a change in a Waves plugin, the upload button does not go green, like PT is not aware of any changes to upload. Most other plugins work fine.
Old 04-17-2016, 12:33 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: Waves plugins and could collab
It seemed to work here but I'll play with it again.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 04-17-2016, 01:36 PM
Thanks. I am aware that Waves do not support PT 12.5 at this time, but I'm wondering if this has a workaround, as it is keeping me from using Waves plugs at the moment.
Edit: PT 12.5 is listed as supported, although the problem persists:
http://www.waves.com/support/tech-specs/supported-hosts
Old 04-17-2016, 02:12 PM
jjnssn jjnssn is offline
I have KMT and a Dorrough Meter on a shared Master Fader. Changing parameters with Waves plug-ins does not change the state of the upload indicator on the track. If I drop a Plug-in Alliance plug-in and upload the track, then change a parameter in the PA plug, the upload indicator lights up. Seems to me it is a bug.
Old 04-17-2016, 02:29 PM
Thanks for chiming in. I have sent a support request to Waves get more information. PT 12.5 is listed as supported here btw:
Old 04-18-2016, 11:39 AM
JFreak's Avatar
JFreak JFreak is offline
Sonnox just recently had to make a quick bugfix to cope with CC so Waves might need to do something similar. Give them some time, it is a new concept...
Janne
Old 04-18-2016, 02:33 PM
TOM@METRO's Avatar
Waves is aware of this, and are investigating.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-19-2016, 04:55 PM
So a work around till Waves can fix. Obviously not elegant probably more easy just to upload changes when finished with 1 button. However and none the less an option.
Try enabling all the parameters of a Waves plug-in, through the Plug-in Automation dialogue box in the plug-in window controls.
You need to press "OK", once all are "added" then go back in and remove all parameters, or any that you don't want or need of the automation parameters you had enabled.
I verified that when the automation enabled parameter changes during playback this does not trigger the upload track indicator to change states unnecessarily.
Also, this does not persist between closing and opening a session.
Old 04-20-2016, 10:23 AM
Thanks!
12.5 Collab not working for me jeff markham Pro Tools 12 3 04-06-2016 11:28 AM
Collab dates??? Analoge Avid Cloud Collaboration 10 08-25-2015 11:59 AM
FS - Waves plugins, AVID plugins Rosco1969 Buy & Sell 12 03-11-2014 11:56 AM
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 06:20 AM
DUC collab track finished! superpenguin79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 11-09-2005 04:16 PM
