pt7.1cs2 and Sony dynamics ilok not found ER 7058
After installing 7.1cs2 i am getting the message sony dynamics ilok auth not found DAE error 7048. It looks like it will load ok once you are in the session and i think and hope it is keeping the settings!! I haven't got time to investigate as i'm just starting a session! Chris
Re: pt7.1cs2 and Sony dynamics ilok not found ER
if it means anything, i occasionally get this with pt 6.9.1cs3, hd|2, os 10.3.8. it happens either when i launch the session, or if i disable the plug-in (cntl-cmd-click). only the sony plugs. i either get the error you get, or the "authorize via ilok" dialogue box comes on. must be something in the sony plug code that loses communication with the ilok auth. i haven't been scientific about when it happens, becasue it is, as i said, occasional.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: pt7.1cs2 and Sony dynamics ilok not found ER 7058
I have been experiencing similar behaviour from the Sony EQ ilok auth for a long time -- only happens occasionally (maybe once a week) and simply hitting cancel, then manually activating the plugs brings them up no problem.
This was happening with PT6.7x, 6.9x and 7.0; with old ilok auth and new sony iLok auth. Session would load just fine, Sony "no ilok" error, cancel -- plugin would load inactive... I'd activate the sony plugs, and eberything would be perfect until it happened again. ONLY Sony EQ iLok auth -- I've never experienced this with any other plugin. Can't seem to troubleshoot, since if I'm opening a session, I want to work on it... not waste time troubleshooting. What does Sony do differently than every other plugin vendor when checking for an iLok auth? Sony? Re-inventing the wheel here?
--Jeremy |
I never used to see this, but since upgrading to the PT7 versions of the Sony plug-ins this has happened to me a couple of times in 6.9.1cs3.
STeve
macmandigital.com |
PT7 Sony Oxfords - intermittent "ILok not found" | blomble | Pro Tools TDM Systems (Mac) | 12 | 01-17-2006 11:41 PM |
CompressorBank VS Sony Oxford Dynamics | Magno | Pro Tools TDM Systems (Mac) | 1 | 08-21-2004 01:50 PM |
Sony Dynamics Problem | Nicolasixxx | Pro Tools TDM Systems (Mac) | 0 | 04-25-2003 08:16 AM |
Sony Dynamics or MCDSP Compressorbank | Johnny Jam | Pro Tools TDM Systems (Mac) | 2 | 12-20-2002 07:53 AM |
sony dynamics carbonized? | AdamFrick | Pro Tools TDM Systems (Mac) | 1 | 12-19-2002 01:27 PM |
