Old 05-09-2017, 02:06 PM
kuaise kuaise is offline
Default Avid Artist Transporter Jog Wheel Problem
hello
The problem is that a wheel works only in one direction. Fail test only gives a positive value when rotating right or left. Did anyone come across the same problem? Is there any kind of information?
Regards
Old 07-06-2017, 06:05 AM
chrismeraz chrismeraz is offline
Default Re: Avid Artist Transporter Jog Wheel Problem
Hi, I don't know what a "fail test" is. However, I had the same problem. After programming the Transporter Jog Wheel, for scrolling up and down for example, it would only work in one direction.
Diagnosis: for some reason, each time I program the jog wheel, only the command for the left direction is saved. This is confirmed by opening the commands again, and seeing that the right direction jog command field is empty.
Solution: I now program only one direction at a time, i.e. program the left jog wheel direction command, close the command window, save, open the command window again and program the right jog wheel direction.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Artist Transport New User Question Regarding Jog wheel Norrie Artist Series 12 06-08-2015 01:00 PM
Artist Transport - Loose Wheel? istation Artist Series 1 01-15-2015 12:41 PM
Confusing problem with Euphonix MC Mix (now Avid Artist Mix) PLEASE HELP almix12 Artist Series 1 01-15-2015 12:10 PM
Using the wheel on Artist Control v2 Trazan Artist Series 8 06-05-2012 11:41 PM
just add new avid artist mix = eucon problem ! klyg Artist Series 8 05-08-2012 02:29 AM
