Old 12-10-2011, 08:59 PM
daveseviltwin daveseviltwin is offline
Default Word Clock Issues "the HW device is at a different sample rate from the open session"
I'm having a serious issue with the internal word clock on my Mbox (3rd gen). I've been trying to diagnose this issue unsuccessfully for 3 weeks. I'll do my best to explain. Sometimes when I open up a session everything will work fine. Then other times I notice that I get the "the HW device is at a different sample rate from the open session" prompt. That's when I know it's going to be a long day. I'm using the internal word clock and it does not change sample rates. My session will stay locked in 44.1 when I'm actually setup to be in 48.
When I open up setup-hardware, nothing happens. In other words, it's a dead command. When I open up the system pref-avid mbox, it will let me change the sample rate from 44.1 to 48 but nothing happens except in Itunes. It does not affect the sample rate of the session at all. Again, I have to stress that some days it will just work fine and then other days it doesn't. I've cleaned all the prefs, reinstalled PT 8 and checked with different hard drives. I hope someone can give me some kind of help with this. I'm in LA and I don't have any of my paperwork with me to get avid help. I don't think I even registered this unit when I bought it because it was rarely ever used. Thanks in advance, David
Macbook-2.1g-120gb hard drive
OSX 10.5.8
PT 8.0.5
External-OWC Neptune 500gb
Avid Mbox 3rd Gen
Old 12-11-2011, 07:30 AM
Default Re: Word Clock Issues "the HW device is at a different sample rate from the open sess
I seem to recall that a batch of 3rd gen Mboxes have this problem, so I would go to the dealer that sold you the unit and see if you can get a replacement, or at least a warranty repair.
Old 12-11-2011, 01:18 PM
I guess it of luck for 2 months then because I don't have any of the original boxes or anything with me in LA. That really doesn't make me day. Is is a word clock failure?
Old 12-11-2011, 06:09 PM
I meant out of luck
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
Can't Open Session- "because Pro Tools could not set Sample rate to specified value Chopper macOS 4 06-27-2013 01:57 PM
Mytek + The HW device is at a different sample rate from the open session glynnp macOS 2 10-20-2011 03:53 PM
HW device is at a different sample rate from the open session bad jitter Pro Tools 9 2 08-16-2011 11:36 AM
Audio clock problems.."Check clock source and sample rate.." Please help! beasleymusic Pro Tools M-Powered (Win) 1 08-03-2011 10:54 PM
