Old 03-30-2011, 05:42 PM
rthomas73 rthomas73 is offline
Default Keyboard midi input not recognized
Pro Tools LE 8 Mbox 2 Mini is not recognizing my keyboard MIDI input. I have a Yamaha PSR-295 that is recognized by my computer, however Pro Tools does not acknowledge it. My Mbox and keyboard are both connected to my PC. I have followed the instructions to record MIDI on an instrument track, but I simply do not get the MIDI sound described in step #11. I've had this software for too long to not get what I need from it. Please help me so I can make very necessary use of this product!
Thanks,
rthomas73
SiSoftware Sandra
Computer
Model : HP Pavilion 061 PJ562AA-ABA a705w
Workgroup : MSHOME
Host Name : MONA
User : HP_Owner
Processor
Model : Intel(R) Celeron(R) CPU 2.93GHz
Speed : 3GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 256kB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 lines per sector
Computer
Mainboard : MSI Gamila/Giovani/Neon series
BIOS : Phoenix Technologies, LTD 3.15 08/05/2004
Bus(es) : ISA X-Bus PCI IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 1.5GB DDR
Chipset
Model : MSI 82845G/GL/GE Brookdale Host-Hub Interface Bridge (B1)
Front Side Bus Speed : 4x 133MHz (532MHz)
Shared Memory : 8MB
Channels : 1
Memory Bus Speed : 2x 222MHz (444MHz)
Memory Module(s)
Memory Module : 12 1GB DDR PC1-3200U DDR1-400 (3-3-3-8 2-11-0-0)
Memory Module : Smart Modular SM5646485D8N6FN 512MB DDR PC1-3200U DDR1-400 (3-4-4-8 2-12-0-0)
Video System
Video Adapter : Intel(R) 82845G/GL/GE/PE/GV Graphics Controller (266MHz, 128MB DDR 64-bit, Integrated Graphics)
Graphics Processor
Storage Devices
Seagate ST340015A (40GB, ATA100, 3.5", 2MB Cache) : 37GB (C:) (D:)
Generic USB SD Reader (USB) : N/A (G:)
Generic USB CF Reader (USB) : N/A (H:)
Generic USB SM Reader (USB) : N/A (I:)
Generic USB MS Reader (USB) : N/A (J:)
LITE-ON COMBO SOHC-4832K (ATA33, DVD-R, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
HP_RECOVERY (D:) : 6GB (FAT32) @ Seagate ST340015A (40GB, ATA100, 3.5", 2MB Cache)
HP_PAVILION (C:) : 32GB (NTFS) @ Seagate ST340015A (40GB, ATA100, 3.5", 2MB Cache)
Optical Drive (E:) : N/A @ LITE-ON COMBO SOHC-4832K (ATA33, DVD-R, CD-RW, 2MB Cache)
Removable Drive (G:) : N/A @ Generic USB SD Reader (USB)
Removable Drive (H:) : N/A @ Generic USB CF Reader (USB)
Removable Drive (I:) : N/A @ Generic USB SM Reader (USB)
Removable Drive (J:) : N/A @ Generic USB MS Reader (USB)
Peripherals
LPC Hub Controller 1 : Intel 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge
LPC Legacy Controller 1 : Winbond W83627THF/THG
Audio Device : MSI 82801DB/DBL AC'97 Audio Controller (ICH4/ICH4-L B0)
Audio Codec : Realtek Semi 0080h
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : MSI 82801DB/DBL (ICH4/ICH4-L) UltraATA/100 EIDE Controller
USB Controller 1 : MSI 82801DB/DBL USB UHCI Controller #1 (ICH4/ICH4-L B0)
USB Controller 2 : MSI 82801DB/DBL USB UHCI Controller #2 (ICH4/ICH4-L B0)
USB Controller 3 : MSI 82801DB/DBL USB UHCI Controller #3 (ICH4/ICH4-L B0)
USB Controller 4 : MSI 82801DB/DBL USB 2.0 EHCI Controller (ICH4/ICH4-L B0)
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Lexmark X1100 Series (4800x1200, USB, Colour)
Printer : CAPTURE FAX BVRP (200x200, Colour)
Scanners and Cameras
Scanner : Lexmark X1100 Series (Scanner, 300x300, USB)
Network Services
Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Performance Enhancing Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 03-30-2011, 08:42 PM
Default Re: Keyboard midi input not recognized
Did you go into the Pro Tools Midi Studio setup window and assign a device and midi port? That needs to be done before any midi device will talk to Pro Tools.
Old 03-31-2011, 03:27 PM
That's what I get for starting with Getting Started. OK, I've started setting up the MIDI Studio Setup and my model is not available, so I chose "None". Therefore, therre are no Input or Output port options. What now?
Midi Input not Recognized kvnlnt MIDI 14 03-27-2011 01:52 AM
Midi keyboard not recognized Hotcrazyfruit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-25-2010 07:58 PM
Mbox 2 MIDI input/ouput not recognized in PT or AMS (again) colinjames MIDI 2 02-21-2010 05:18 PM
Manual MIDI vs Keyboard Input AirborneFO MIDI 3 05-19-2009 11:12 AM
Using your computer keyboard as input for MIDI PaulG1522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-03-2007 02:09 PM
