Old 10-17-2009, 03:02 AM
Dingo90 Dingo90 is offline
Default auto matching pull factors + frame rate + timecode rate
Hypothetically, if I am working on a project that's being edited on 29.97 frames per second on the picture editor's editing system and for one reason or another, I have had to work on the sound design using 23.97 as my PT session timecode rate.
Am I correct to assume if that I go to my session setup and change my session timecode to 29.97 frames with "auto pull match" checked, that when I export my audio stems, the stems will sync up properly with the picture editor's editing session of 29.97 frames?
thanks in advance
Jack
Old 10-17-2009, 04:16 AM
Postman Postman is offline
Default Re: auto matching pull factors + frame rate + timecode rate
Yes
ALL audio for video should be delivered at EXACTLY 48kHz, no pullup or pulldown. So, if your original session is 48kHz AND no pullup/down was checked in Pro Tools, the audio is already running at the right speed. There is an exact 3:2 relationship between 29.97 and 23.976 which does not require any change of playback speed. No pullup/pulldown is wanted.
HTML code is On
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
Auto Match Pull Factors & 25fps to 24fps workflow tj_davies Post - Surround - Video 4 03-05-2008 09:26 AM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
Best TimeCode Frame Rate - Live Concert Recording? SportsSounds Post - Surround - Video 10 05-11-2006 11:09 AM
"Auto Match Pull Factors" lancebrwn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2003 10:37 AM
