Old 04-02-2007, 03:26 PM
Blomski Blomski is offline
Default Loop problem
I have a problem with pro tools LE on a mini mac OSX 10.4.9
Mini mac is single core and has 2 GB ram.
I use this mac mini for an Art instalation.
let me explain;
An artist made a huge cloud of spinnaker. It's blown up with air by a ventilator. There are 32 TL's in it and near the installation there are some speakers.
The vent and TL's are on a dimmer pack witch is controlled by a LanBox. This lanbox controlls the dimmer via DMX and sends cue's. The cue's are for the TL and vent. It tells them when to dim light and when to stop and start the vent.
The effect is a breathing cloud witch light's up and go light's out, in combination with audio.
for a small picture -> http://www.brabantsdagblad.nl/regios...cle1238077.ece
Now here is the point.
I made 1 stereo loop of 16 seconds in pro tools and i command the cue's of the lanbox via midi.
this are some controller numbers for executing the cue's in the lanbox to control the light and fan.
BUT, after 2.5 hours (more or less), pro tools is hanging and give an error;
A CPU overload error occured. If this happend often, try increase the H/W Buffer Size” in the Playback Engine Dialog or remove some plug-ins (-6101)
and
CPU usage is holding off audio. Remove some plug-ins, delete some tracks, or increase the H/W buffer Size in the Playback Engine Dialog (-6104)
Well the buffer size is at his top 2048.
Why does pro tools do this? I also used digidesign advise of disable spotlight etc.
I don't get it. There is enough CPU power to loop this and pro tools still crashes.
Who can give me an answer?
Pro tools LE 7.1.1.
intel mini mac OSX 10.4.9
2 GB ram
MBOX 2
thanx in advance.
M.
Old 04-04-2007, 06:36 AM
AE AE is offline
Default Re: Loop problem
you may have uncovered some sort of obscure pro tools bug. i don't imagine digi tests this type of scenario.
i'd try using a different application, something a bit simpler and more bulletproof. quicktime or adobe director could work.
Old 04-04-2007, 09:59 AM
hehe, thanx for the answer. It's also not on the right section, i noticed. TDM, I whish I had it I am going to mail digi directly.
Cheers.
M.
Loop problem in PT 10? 3.2 famelittle macOS 1 03-13-2013 12:40 AM
Loop-record problem JNS Pro Tools TDM Systems (Mac) 3 01-25-2011 08:01 AM
Loop problem Blomski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-05-2007 07:50 AM
Loop problem Blomski Pro Tools TDM Systems (Mac) 4 04-03-2007 04:40 PM
Loop problem Q-ic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-01-2006 10:36 AM
