Old 08-27-2006, 12:57 PM
elv1s1sal1ve elv1s1sal1ve is offline
Default two different time signatures in one session?
How do I assign a 6/8 time signature to one segment of a session and 4/4 to another?
Gateway 7510GX, AMD Athlon 64 3700+ 2.39 GHz, Windows XP Pro, PTLE 7.3.1.123, MBox, 1 GB RAM, external Seagate 150 GB HD
Old 08-27-2006, 02:11 PM
nikki-k nikki-k is offline
Default Re: two different time signatures in one session?
Simplest way is to have the Meter Ruler showing (via View menu, Rulers), align playhead/cursor where you want the Meter change to occur. Click + sign next to "Meter" in the meter ruler (left end), be sure time to insert is correct, enter time sig in proper fields, select the beat (whole, half, quarter, etc) and hit enter. Meter change applies til session end, unless another meter change is encountered later in the timeline.
To do a 4|4 to 6|8, and back to 4|4, you would simply insert the 6|8 where you want, since 4|4 is the default meter already, and then insert the change back to 4|4 where you want. SImple.
For additional, or more advanced, meter instructions, the Ref Guide has info.
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 08-28-2006, 05:33 PM
Thanks nikki-k. Big help! You are awesome! But now I've got another question. I've since decided I want to try the following:
two 3/4 measures followed by one 2/4 measure (i think). When I assign the meter changes, I still get 4 beats in the 2/4 measure. Maybe my music theory is a little lacking here, so let me elaborate. I want the following results...1,2,3,1,2,3,1,2...but I am getting 1,2,3,1,2,3,1,2,3,4. I guess I could just change the actual tempo of the 2/4 measure to get the desired results, but I'm thinking I'm missing something more simple here. Any ideas? Thanks for your time.
Old 08-28-2006, 07:36 PM
If it's a 2/4 bar (check the meter timeline) it should only count 2 beats to the bar.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
how to change time signatures? rowlando Pro Tools SE and Essential (Mac) 12 12-11-2019 10:21 PM
Set up PT for 3/4 5/4 6/8 ... time signatures KGB2011 Pro Tools M-Powered (Win) 4 10-11-2010 07:38 PM
Other time signatures with Boom other than 4/4 MrBibidy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-21-2010 12:53 AM
Strike 1.5 Odd Time Signatures Amin7b5 Virtual Instruments 1 04-06-2010 08:02 AM
Pro Tools and Odd Time signatures RhythmMaster Pro Tools TDM Systems (Mac) 2 02-03-2006 07:49 AM
