PT v.6.4 - realtime fade don\'t work....!?
hi,
I use a HDIII accel with PT v.6.4... my realtime fading don΄t work any more? what have I done wrong? if someone knows how to solve this please send me a mail... 1000-thanks charlie |
Re: PT v.6.4 - realtime fade don\'t work....!?
In the Preferences set your auto fade to the desired amount.
Default setting is 0 msec, in other words off. |
hi and thanks diewel,
I wished this were the problem but this kind of fading is working well:) my problem is that I can΄t make my fades when protools is running.... I can add plug-ins and nudge audio etc.... but the fade funktion is gone?!? thanks for trying to help me out.. any new idea for a solution are welcome:) c |
Can you please explain what you mean...???
Do you mean you: a) Can't automate a fade? b) Can't create a fade using Command+F? c) Can't create a fade while in playback using Command+F? d) Can't create a fade using the modifier keys and F key? You should check if you've suspended tasks during playback. Rail
hi,
Correct c) Can't create a fade while in playback using Command+F? any idea? thanks charlie |
eeeh... d) is right as well:
Can't create a fade using the modifier keys and F key? c |
Can you drag the edge of either region left or right over the adjacent region with the Trim Tool?
Have you tried deleting your prefs file as explained in the sticky Troubleshooting thread? Rail
rail, thanks!
take care charlie |
Automatic fade in and fade out occurring after recording | digicake | macOS | 5 | 11-05-2013 01:07 PM |
PT8CS2 BUG - Region Trim & Fade does not work when Zoomed @ Sample Level | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 03-02-2009 10:13 AM |
Smart tool fade doesn't work on some tracks | ivfdad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2009 06:03 PM |
How to apply fade-ins and fade-outs on selected regions? | Halstein | Pro Tools TDM Systems (Mac) | 2 | 05-09-2007 03:07 PM |
Fade won't work? | Esteban WB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-15-2003 09:03 AM |
