Old 09-27-2013, 04:46 AM
crizdee's Avatar
crizdee crizdee is offline
Default Globals not working on all groups
I have global settings ticked for follow globals on every individual group and global settings for insert J ticked for controls and bypass.
I'm expecting all inserts in insert slot J to now follow controls and bypass, but they are not. the individual groups are still working like they are set to individual attributes for insert J but nothing is following globally
Im sure I've had this working in the past on every group or individual track, so not sure why its not working as expected.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-27-2013, 06:57 AM
joachim's Avatar
joachim joachim is offline
Default Re: Globals not working on all groups
In the group, where globals are not working : do they contain audio tracks of mono AND stereo format (or in general : different channel formats) ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 09-27-2013, 07:57 AM
crizdee's Avatar
Its none of the groups working as a whole? they work individually as a group but i was expecting all tracks in all groups to be controllable using the global setting. so control one plugin in insert J and all plugins in J would follow.
Individual attributes for each group is not activated just global settings are set for insert J so was expecting all inserts on J to be linked globally.
I know the mono and stereo tracks don't link and have to be controlled separately etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-29-2013, 03:31 AM
joachim's Avatar
Does it happen with certain plugins only ? Even with the stock plugins ?
What kind of groups (mix / mix+edit) ?
Works fine on 10.3.7 HD.
Old 10-14-2013, 05:19 AM
joachim's Avatar
Just to rule it out, don't want to question your knowledge (again) :
"Link Mix and Edit Group Enables" is not deselected and the edit/mix group was not enabled in the edit window ?
I know, you know that behaviour, but others might like the info.
Region Groups-->Clip Groups Import File Menu Not working minister Pro Tools 11 0 01-06-2014 11:23 AM
Some groups not working correctly albee1952 Pro Tools 10 4 10-17-2013 05:47 PM
Region Groups in PT9 HD not working as they should?? johnpaulgeorgeringo macOS 0 06-11-2011 10:44 AM
Groups not working jlnelson19 Pro Tools 9 1 11-21-2010 05:44 PM
Groups functions not working stevedresser83 Pro Tools M-Powered (Mac) 0 06-13-2009 08:07 AM
