Old 08-24-2006, 01:12 AM
Aquarius Aquarius is offline
Default 7.2 missing files / relinking / HELP !!!
I don't know if that has been covered in another post but PT is "loosing" pathes to soundfiles Big Time !
I'm working on a project with a lot of Sfx imported into the session : They all play fine until I close the session....If I open it again, I get the dialog about missing files and relinking....
It's a real drag when you have nearly 100 hundred files to manually commit (automatically doesn't find them) !
One workaround I found is to apply a consolodiate around the region to make sure it's not going loose... (
Please note this only applies to files IMPORTED ! If I record a voice-over : No Problem !!!
I hope a fix is coming soon.
A.
G5 2X2.5
3.5 g Ram
OS X.4.3
PT HD Accel3 7.2
Old 08-24-2006, 03:05 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: 7.2 missing files / relinking / HELP !!!
There seems to be a problem with inported audio files and drag and drop files in 7.2!
I've been having lots of problems getting files into PT! Check this post here.....
http://duc.digidesign.com/showflat.p...10394961039441
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-24-2006, 06:18 AM
minister's Avatar
minister minister is offline
Hi Aquarius,
are these files from mTools?
unfortunately, this is a known problem.
solution? don't work at all and find a nice woman with lots of money. ...and then introduce me to her sister.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 08-26-2006, 05:47 AM
Hi Minister,
Yes, that would be using MTools !
I have to manually relink everytime....I do hope Digi's coming with a fix REAL SOON !!!
Cheers,
A
Old 09-07-2006, 03:03 AM
Burns Burns is offline
Hi Minister,
Cheers,
A
Same problem here, I use Soundminer and Protools 7.1 cs9. The strange thing is not all the time.... by the way Aquarius, try Soundminer, it's very convenient and so much better than mtools.
Old 09-07-2006, 04:35 AM
Does Soundminer use the same CD links index as MTools ?
I don't want to convert all my files again...
Cheers,
A.
Missing files, Relinking, Select the files... Kdose macOS 0 02-27-2014 09:53 PM
RELINKING MISSING FILES Siddhant Bhatia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-27-2007 01:52 PM
RELINKING MISSING FILES Siddhant Bhatia Tips & Tricks 0 04-27-2007 05:53 AM
missing audio files relinking... Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2006 04:59 PM
relinking missing regions??? lightning ad Post - Surround - Video 5 03-15-2006 08:38 AM
