9600 Upgraded-distorted Plug-ins
Hi, I am using Mac9600 with sonnet G3 400 Proseccor. I know this is not supported but is there anybody else using this. My plugz sometime sound distorted? Could it be the (not supported) Adaptec 29160N Scussi card I'm using? I'm gonna change to ATTO. Is anyone familiar with this Proseccor upgrade? [email protected]
Re: 9600 Upgraded-distorted Plug-ins
I have a 9600 with a sonnet G3(400) and it works brilliant from the start on. Adaptec 2940 as scsi. NO g4 for me! Both RTAS and TDM work ok. 400 MB RAM. I have no idea where distrted PI'ns come fom, are you sure it is the G3, can you replace the 9600 and then see if it disappears?
I don't know what combination of TDM and RTAS plugs you are using.
In the event you are substituting TDM plugs for RTAS thanks to the added power of your G3, maybe you have a level related issue, since TDM and RTAS do not use the same processing system The answerbase link below may be of some help to try understand the problem. If that *is* your problem, the answer is simple : try attenuating the input of the plugins and see if the distortion disappears. Eq plugs are particularly sensitive to this, whether when boosting or even when attenuating some frequencies ! This phenomena is very well explained on the waves q10 manual (link below) excerpt : "Under certain circumstances, internal clipping can occur. With high level files (already normalized, or with high peaks), several situations can occur that may cause peaks that did not exist in the unequalized signal. This is true even for filters that have no gain, such as a high-pass filter, or for filters with a cut." answerbase link Q10 manual (heavy pdf 708k) |
Eleven Plug-In distorted | jwilkers | Pro Tools M-Powered (Mac) | 1 | 01-07-2011 07:17 PM |
G3(300mhz upgraded 9500 or a 9600/350 (604ev) and digi001? | ckerian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-22-2002 07:52 AM |
9600 upgraded to G3/400 processor=sluggish | legativity | Pro Tools TDM Systems (Mac) | 2 | 07-15-2001 04:22 AM |
Digital Time Piece / ClockWorks not communicating with upgraded 9600 | Mick F. Cantarella | Pro Tools TDM Systems (Mac) | 0 | 12-31-2000 03:20 PM |
Replacing stock 9600/350 (upgraded G3/400) video card | Marco Migliari | Pro Tools TDM Systems (Mac) | 0 | 11-13-2000 06:51 AM |
