Old 09-22-2020, 12:44 PM
jjsoundoc jjsoundoc is offline
Default Swapping gpu's?
I have a home set-up with 2 desktop video monitors that are fed by a mac mini's (2018) internal video card. I have a large monitor for video playback that's fed by an external Aja i0 4k.
I'd like to swap one of the desktop monitors with a high-res monitor that would also be used for photo editing. The mac card doesn't have specs that would work with the monitor, the Aja io would work.
Question is; can I use the internal mac gpu for video playback on the large monitor, and use the Aja IO for one of the desktop monitors and use it as the primary monitor as a permanent set-up?
Thanks for any help.
JJ
Old 09-27-2020, 06:22 AM
Brandonx1 Brandonx1 is offline
Default Re: Swapping gpu's?
I don't think you can use the ajaio for a desktop display. Only video output, right?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 09-27-2020, 07:01 PM
reichman's Avatar
reichman reichman is offline
Sorry, JJ, pretty sure it's not possible. You can check with AJA, but I've never seen it, and I think the AJA video interfaces don't have GPUs at all. You might be a candidate for an eGPU...
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 09-28-2020, 05:56 AM
LDS LDS is offline
My AJA interface only works as a dedicated video playback device. No desktop display whatsoever... which is a bummer, but it probably rolls entirely into the copy protection related to HDMI.
Out of curiosity, what makes the Mac Mini GPU unsuitable for your needs? They are qualified by Apple to support up to three 4K displays simultaneously.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
HTML code is On
Swapping PT MP9 to a new computer jglunt2112 Pro Tools M-Powered (Win) 2 01-09-2013 11:04 AM
swapping out my C: drive...? K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 05-01-2007 11:25 AM
Swapping out PC Soulsanctu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-07-2005 07:12 PM
Hot swapping the 001 QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2005 02:22 PM
Swapping Mobo & CPU?! xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-25-2004 01:03 PM
