PT 10: "Can't get audio from the drive fast enough"
Ok, so all of a sudden this message keeps popping up:
DAE can't get audio from the drive(s) fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwith or CPU load (-9073) The session played back fine before. Rebooting sometimes solves the issue, sometimes not so much. PT 10 HD 2 system, 192 voices, audio play back from a Lacie d2 FW800 disk, movie plays back from internal disk. Computer is on LAN. 2 x 2.4 GHz Quad, 16 GB Ram. |
Re: PT 10: "Can't get audio from the drive fast enough"
What version of OSX are you running? Snow Leopard has given me endless firewire issues and i've kind of found a fix for it. Did you upgrade your operating system when moving up to PT 10?
Yush |
Are overviews being calculated in the task manager?
10.6.8
Can i suggest you try the following method:
I too was having endless firewire buffer trouble on my Mac Pro (Quad Xeon) with PT10LE and my MBox3 Pro, as well as with streaming audio from firewire 800 drives until i stumbled along this timely fix at the apple discussion forums. I'm running 10.6.8 as well and apparently there are still issues with the Firewire kext's, but they show up for some users and not for others (I think it might be machine dependent as i didn't need to fix for the same setup on my MBP, which is newer). You can download the older Leopard firewire kext's (10.5.6) from my iDisk here https://files.me.com/ayushahuja/6eewtw These files need to replace the files found in Macintosh HD/System/Library/Extensions Please backup your 10.6.8 kext files before you replace them incase something drastic happens (Also note that the 10.6.8. extensions folder doesn't have a file called FireWireStorageDeviceSpecifics.kext, so there are only 5 files to backup) And then reboot, and try running your session again :) I hope this helps, I haven't had a single 'drive slow' or 'buffer underrun' error since (fingers crossed, almost 2 months now). Yush |
Great solution. Makes me wish i was having the problem so i could utilize it!
Ken Wilkinson http://kenwilkinson.tv Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1 2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5 |
Yush
I did what you suggested. As a result, the FW disks cannot be found anymore. I replaced your kext files with the ones I backuped, the problem remains. Guess it broke the FW bus. |
Hey Mr. Armadillo,
I'm sorry for causing such trouble! After you replace the kext files, I believe you need to (for either leopard or SL versions): 1) repair disk permissions 2)and then reboot. Hopefully that might fix it. Yush |
Thanks! That did the trick. However, it didn't solve the "not fast enough" error.
"DAE can't get audio from hard drive fast enough..." | jervin | Pro Tools TDM Systems (Win) | 17 | 06-13-2014 08:04 PM |
"Can't get audio from the drive fast enough" -9073 | mingojr | macOS | 22 | 08-15-2013 09:45 AM |
"DAE can't get audio from the drive(s) fast enough. Help!! | Schumannz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-22-2012 10:38 AM |
Getting "DAE can't get audio fast enough" msg after applying crossfade | EricWillhelm | macOS | 4 | 09-06-2011 07:51 PM |
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or | iminzayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2010 10:28 PM |
