Old 03-17-2003, 07:05 AM
yin7yang64 yin7yang64 is offline
Default Problem getting both controller and soft synth to work in my studio
I'm brand new to working with MIDI so I'm sure this is just a matter of setting up the configuration correctly.
I have a Digi002 unit, a Cooper CS-10/2 MIDI based control surface, and a Oxygen 8 synth controller that operates via USB. The CS-10/2 controller is plugged into the MIDI in and out on the Digi002 and works just fine...until I plug the Oxygen 8 into the USB port and start working with the synth software that came with the Digi002 (SampleTank, Pro-52). Then the synth works just fine, but I've lost the CS-10/2.
I have gone to the OMS Setup screens and tried configuing the connections, but each time I return, the generic "?" icons are back and I get a "lost communication with Cooper controller" error message. There's also a pull down menu under peripherals that I've visited repeatedly to select the Cooper controller, but that doesn't resolve the problem. To make matters more complicated, the Oxygen 8 driver installation instructions say that it's supposed to install a couple of specific Keystation extensions, but I've tried running it a couple times and still can't find those extensions. There is a MIDI USB extension that seems to be providing the connectivity, but it's not the one named in the instruction manual.
Don't know if this is one issue or several. Any light you can shed would be appreciated. I'm running this setup on a 800 MHz G4 PowerMac with 512 MB of RAM, OS 9.2.2.
Soft Synth / MIDI Controller Recommendations? sweetbabysims 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-21-2006 04:35 PM
midi controller/soft synth setup corTools General Discussion 0 03-18-2004 06:11 AM
Soft synth vs Hard synth! Reason, Pro 52, V Statio Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-08-2003 10:51 AM
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? rtcstudio Pro Tools TDM Systems (Mac) 3 11-16-2002 07:57 PM
Best Soft Synth Please Dutchmuzik Pro Tools TDM Systems (Mac) 7 09-28-2001 11:15 PM
