midi merge timing question
I wondered for a while how to merge MIDI notes so that they retain the original timing, such as slightly after the beat.
I have googled this a lot, but probably haven't posed the query correctly. On the attached I want the notes on the right (circled in red) to match the timing of the notes on the left (boxed in green). Is this possible? What setting do I have to change or tool must I use? |
Re: midi merge timing question
You can extract the timing from notes with Beat Detective, save it to the clipboard or to disk, then quantize other notes with the extracted template.
Or, use relative grid mode, and Alt+drag the notes over to copy them. EDIT: I mention relative grid mode since it looks like you're after an exact copy.
Studio rig - Pro Tools|HDX 2018.7 | Logic Pro X.4.2 | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5 Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X.4.2 | OS 10.12.6 Last edited by Stig Eliassen; 04-17-2018 at 11:35 PM. Reason: More info |
Thanks again! |
if you want to copy and then merge paste, i find the easiest way is to just add an extra note that is on the grid and copy that along with your selection just so you can line it up again, and then delete the extra note. if that makes sense. but yeah, relative grid is great if it's not too far to drag.
Thanks--I'll try that as well!
This worked like a charm! Thanks.
Midi Notes already recorded drop when midi merge recording | EdwardG | Pro Tools 12 | 5 | 07-03-2019 12:44 AM |
Midi Merge | jino_f_a | Pro Tools M-Powered (Mac) | 4 | 06-19-2009 03:19 PM |
MIDI Merge | Denkelag | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-17-2007 03:44 AM |
MIDI v USB a question of timing | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-15-2005 04:42 AM |
MIDI Merge | Greg B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-29-2005 12:09 AM |
