Xpand2 Help!
Everytime I use mini grand,Boom, Vacuum, I get audio. They are easy to load the presets, but Xpand2, WTF! I load a preset and cant get nothing out of it. Im doing everything right. Nothing is muted, record enable is set, but I cant seem to get to hear anything. Can anyone help?
Re: Xpand2 Help!
So, If you make a new session, add a stereo instrument track, insert xpand..
What exactly happens? Do you get a MIDI input to the track? (View>Mix window views... Instruments needs to be checked to see the MIDI meter) Do either of the meters move? Are you trying to choose presets from the 4 channels in Xpand or from the usual preset list in the top of the plugin display?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: Xpand2 Help!
When I make a new session, nothing happens. I create a Instrument track, add Xpand2, arm it, nothing happens. Usually when you add something like Boom, its the Factory preset. So when I hit my Axiom keyboard, I get whats on the plugin. None of the meters move when I do the exact same thing when loading Xpand2. I will even create a MIDI track just to fool around. When I do that I get meters on my MIDI track. But Xpand2, I have no idea what to do. It should be easy, Load the plug in, pick a preset and hit my keys. I should hear something. How do I use Xpand2??? Or better yet, How can I preview the presets?
Re: Xpand2 Help!
Still @ it hunh? U never answered in ur other thread(or @ least I don't recall) as to whether or not u see any of ur presets as I asked? Sounds like they're not in the rite location or maybe u double installed & the folder may be doubled... just a whim...
Re: Xpand2 Help!
When I create a new instance of Xpand2, the plug loads with <factory default> in the preset display and the first slot has "001 Bright Pads - Beneath the Waves+" loaded. I would assume that is the standard factory default because i have never done anything to change the default..
If you click on the Librarian Menu (right beneath the Preset heading) do you see these choices?: 01 Soft Pads 02 Bright Pads 03 Huge Pads etc.. If not then maybe you're not pointed at the default settings folder.. Click on the Presets Settings menu (little triangle next to "Preset") then choose Settings Preferences>Set Root Settings Folder... The folder that you should choose is <Mac HD>/Library/Application Support/Digidesign/Plug-in Settings Edit... Hey KB.. Already workin' on em, eh?
Re: Xpand2 Help!
Hey Flommer... Yeah, trying to anyway
Re: Xpand2 Help!
hey everyone
Im sorry if this is in the wrong section. Im new, and am in dier need of a quick answer. Its regarding xpand2 and boom... How do you get the sounds from xpand2 into boom? I like boom, But i would like to get the sounds that are in xpand into boom.. Im going to school for pro tools. but.. for some reason the teacher doesn't know the answer. I would appreciate a answer. thank you and again sorry if this is the wrong section.. |
Re: Xpand2 Help!
Re: Xpand2 Help!
Thatz b/c there is no answer for that...
edit:Flommer beat me to it... Heyyyy Flommer
Re: Xpand2 Help!
By 1 minute... he he..
Not even Xpand2 in PT 11?? | BGMusic | macOS | 3 | 07-07-2013 11:52 AM |
Xpand2.big? | foulkown | Windows | 28 | 10-01-2012 05:35 PM |
Xpand2 | Barb4543 | Windows | 2 | 04-19-2012 08:24 PM |
"XPAND2.big" Xpand2 Can't Finde The Factory Content?? | toolgirl | macOS | 1 | 02-29-2012 08:04 PM |
"Xpand2.big" Xpand2 closes PT10 | RamenShaman | macOS | 3 | 01-03-2012 08:44 PM |
